Results 1 to 10 of 11
Thread: Recovery points.
    Apr 2013
    Cairns
    Recovery points.
    I got growled at by members here because I had to wrap a strap around my bar to get unstuck due to my bar having NO recovery points, so I came up with a plan to fit them on the LR factory bar. 12mm steel plate welded in. Sorry about some of the pics, rather crap camera on my phone. A few better ones after powder coating.
    Oct 2017
    AU
    Adr compliance?
    Great work but as they may ding the pedestrians....
    I use jate rings
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by martnH View Post
    Adr compliance?
    I use jate rings
    Depends on the year his Defender is. If you hit a pedestrian with a Defender with a Bullbar on it, you'll be having a bad day anyway.
    Not sure why people can't be happy about things others do rather than drag them down all the time to be honest.
    DAMINK Guest
    Yep i like your thinking mate. Nice and strong.
    I have to ask though if i may.
    Why did you do button tacks on the front instead of running a continuous bead like you did to the inside? Or are they all button tacks?
    Either way it wont be coming off any time soon. I had thought of doing the same but got worried about forward protrusion.
    Oct 2017
    AU
    Sorry I am very happy about his work.
    Well done
    It will work great
    Fantastic
    Quote Originally Posted by Homestar View Post
    Oct 2017
    AU
    I use Jate rings. They are low so that the truck will be pulled forward and also upwards
    I upgraded the bolts to high tensile 12.9. that bolts hole I used is reinforced from factory with support tube inside chassis.
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    My recovery points are incorporated with my steering gaurd thanks to Ben at APT.
    APT Steering Guard | Defender
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Narre Warren South
    Funny, I thought exactly the same about ADR's because of some Perentie owners having to cut off similar protrusions on their bumpers.
    Not sure if it varied by State or just the individual Roadworthy Tester.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Feb 2005
    Recovery points.
    Well, done.......looks like a good solution
    If you get pulled over all they are going to ask is they are cut off......no worse than winch rollers, good, wire rope, spotties the proteude from bars....
    DAMINK Guest
    The moment i get some time im gunna make some.
    Dont get any damn time to turn the welder on. Always working with wood.... Man that makes me feel dirty even sayin it.
    Im a steel guy. Hate wood.
