Results 1 to 10 of 29
Thread: K&N air filter
    J.K Guest
    K&N air filter
    Hi all, my 2010 TDV6 D4 is about due for a service, was considering using a K&N air filter as the replacement, any one used these and do they improve performance at all ?
    cheers JK
    Ocean Reef WA
    If that's the one you smother with oil I wouldn't bother personally. I used one for a while on a 300Tdi Disco I had many years ago and found no difference in anything except the mess to wash it when clogged with dust.
    Threw it out after a couple of trips.
    Now I take a spare OME filter if going off road and also just gently knock much of the dust out if I've been on really dusty tracks. Seems to do the trick OK.
    AlanH.
    JDNSW's Avatar
    A search on this forum should find quite a bit on these filters. (Not much of it very favourable)
    As far as I can see the overall effect is that performance, with boost and fuel quantity controlled by the engine management system, should be unchanged. The reduction in intake silencing should give a significant improvement in the impression of performance (i.e. noisier), and the major reduction in filtering of intake air would see a reduction in engine life, depending on environment , of anything from maybe 10% to 90%.
    99.87 MB
    With D2's the thinking is that LandRover brand filters are the most efficeint/effective, I would assume the same in this case also. Aside from using Finer/Uni filters as snorkel socks, I don't think there is a benefit on a 4WD.
    Slunnie
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    this K&N thing has been flogged extensively in this forum.
    most K&N enthusiasts also have a hi-clone fitted.
    they are both as operationally efficient as each other.
    Feb 2013
    Ballarat,Vic,Aus
    I think there an expensive ****. The ones I've looked at ... sure they will make the inducation a lot louder .... and be fantastic hot air intakes (which will decrease performance for sure). Given I can see daylight through them quite readily ... they are certainly crap at filtering air. They might stop leaves and stones, but they aren't stopping dust if I can see through them .....
    I may have been looking at the "sports" air cleaners though. Who knows, there standard replacement filters might be quite ok ( I'd never use one over a decent ribbed cardboard type aircleaner though .... not in a million years). The surface area for filtering on a well made OEM filters is a million times better than a small see through pod filter.
    seeya
    Shane L.
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yep, as mentioned, good for screening out large insects, stones and kittens from your intake but not much else. Steer clear.
    Mar 2012
    melbourne
    I used one in my D1 for a few years, from my experience providing you oil them correctly they filter better than a cheap paper filter. On really dusty tracks with the paper filters I would get a film of extreemly fine dust on the intake side after a few days, with the correctly oiled K&N it didn't happen. The total opposite from what a lot of people say. The issue is they clog up to quick and too much or not enough oil and that's where the issues arise.
    Would I use one with the D4, no way, just stick with standard
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    May 2016
    K&N filters (and their copies) aren’t known in the automotive industry as ‘rock catchers’ for no reason. They may flow better, but there’s a reason for that. They are quite porous.
    I’ve worked on numerous bikes fitted with them, and have always found dusting on the downstream of the filter in the intake piping.
    You can work out what that means.
    I steer clear of them...
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by discomatt69 View Post
    I guarentee you'd still have dust get past the oil - a memebr who used to frequent here was one of only a handful of filtration Engineers in the country. He did a lot of tests - posted here somewhere - on air filters - OEM, aftermarket, K&N, etc - in all different conditions, brand new, dusty, clogged, just cleaned, oiled or not in the case of the K&N. The K&N always came out at the bottom for filtration - by an alarming amount, and the particulate size they let through was scary.
    No 'I think' or 'a mate said' - actual scientific testing. There are plenty here that have seen tyese results - it would change your mind in a flash.
    I think a well maintained, cleaned but used OEM paper filter scored best for actual filtration - better than a brand new one.
