Thread: 3 vs 5 bearing engine
    Dec 2010
    Kiewa Valley, VIC
    How do you tell the difference between these 2 motors without pulling the sump?
    Mustlust
    1950 Series 1 80in lights behind grill
    1950 Series 1 80in rolling chassis looking for a body
    1956 Series 1 86in
    1956 Series 1 107
    1957 Series 1 88in
    1967 Mustang coupe 347 stroker
    2011 Discovery 4 3.0
    2009 110 utility 2.4tdci
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    by their engine numbers and their age
    JDNSW's Avatar
    All threads (and hence heads and nuts) on the 5 bearing are metric, on the 3 bearing they are UNF with a few Whitworth, and probably a few BSF.
    The five bearing has a pattern of reinforcing ribs on the sides of the crankcase that are not on the 3 bearing.
    Five bearing are very scarce in Australia - apparently not fitted to any local production, but station wagons and some others were imported built up, and there were later private imports.
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    and the 5 bearing seems to be the one that puts a window in the block most often
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Jul 2012
    Colour
    Hello from New Hampshire.
    Beyond what has already been offered - all largely correct - the block colours were also different.
    The 3 bearing block was the traditional Admiralty Grey while the 5 bearing block was Ochre Red or some hue thereabouts. The heads might have been painted black.
    As also noted, these motors generally didn’t make it into locally assembled trucks.
    Neil
