Penrite Progear 75W90 PRO GEAR 75W-90 (Full Syn.) | Penrite Oil Supercheap and Repco will stick it.
I got to do a basic oil service on my car tomorrow and going to head out soon to buy oil filter.
Also my diffs are overdue on my revised service interval so I will do them also - no e-diff. Normally I can hunt around and find Castrol SAF-XO - 75W/90 spec grade oil but I dont have the time today.
What is the "agreed" alternative that I can get at Supercheap/Repco/Auto 1/Bursons?
 Wizard
						Subscriber
						Wizard
						SubscriberPenrite Progear 75W90 PRO GEAR 75W-90 (Full Syn.) | Penrite Oil Supercheap and Repco will stick it.
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
Castrol's website shows Castrol Syntrax Longlife 75W-90 is the replacement for the SAF-XO
_________________________
1996 D1 V8 - gone
2002 D2 Td5 ES- gone but still running elsewhere
2013 D4 SDV6 HSE - gone
2023 Defender 110SE D300
That's what I've just put in mine front and rear (no E-diff for me so this does both) - excellent stuff.
I also just put in the Royal Purple Synchromax into the Transfer case and no issues so far. Been about ~60,000km since the last Transfer Case oil change.
RP is also available from SCA (on line order only - they don't carry it in store here in WA)
Eric
Castrol Syntrax Long Life, Penrite Pro Gear, Motul Gear 300 (Canberra Motor Cycle Centre) Shell Spirax S6 AXME, Caltex Delo SynGear XDM
Take your pick.
Shane used Pro Gear and experienced elevated Fe levels but that can happen when a new oil/add package is introduced.
It will tend to displace the old sulphur/phos additive package along with I'm guessing bits of asperites.
In not sure if he dumped it or continued to measure a trend as generally the Fe levels drop and taper off in that situation.
Cant recall at what point I mentioned on the forum regard the FE levels. But I've so far had 3 samples on both the front and rear with a change in the middle. Last samples where improved compared to the first sample which was around half the kms. Using the progear still and haven't changed oil brand/type. Next sample will be more of a comparison with the first as the kms on the oil will be similar
Shane
2005 D3 TDV6 loaded to the brim with 4 kids!
http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
Thanks for the responses - I went for the Penrite as it was handy.
Is it ok to use the Penrite ProGear in the transfer case?
A little knowledgeable bird on here did think that Rock Oil TF870 is the same as IYK500010, 'special transfer case fluid.'
But to save $40 every couple of years in using another product, in my view the 'special transfer case fluid' is the way to go.
