Results 1 to 2 of 2
Thread: Nanocom Original Question
    Jan 2009
    Kuranda, Far North Queensland
    I have a 1999 Defender TD5 Extreme and am not sure what I should set the Immobilizer as: DDS, SPIDER, MEMS-TD5, GEMS, EDC. Reason I ask is that the immobiliser light is staying on and the Mems Failure Indicator is flashing so I guess something is not right in my settings. I have gone into test settings and turn hazard light on/off which works but turning the Failure Indicator on/off has not effect.
    Hope someone can help. At least it is not causing any problems (everything still works as it should) and I suppose it will eventually fix itself when the bulb burns out but I would prefer a better solution...
    Howard
    Jul 2014
    west of Transylvania
    It's the one with Td5 in it, all the others are for earlier or petrol modells
