Results 1 to 10 of 23
Thread: Simpson washup
    Jul 2010
    Simpson washup
    Hi all,
    We did a Simpson desert crossing East to West a few weeks back now and then up through the centre and back towards Brisbane via Mt Isa and Longreach. The roughest bit was the last 10km before Mt Dare. We had two issues with the Defender (2012 2.2).
    First, the air conditioner stopped working somewhere between Birdsville and Alice Springs. We only really noticed it approaching Tennant Creek where it was about 35 degrees outside (it had been freezing in the mornings in the Simpson desert). Got someone to look at it in Mt Isa; they said there was stone damage to the condenser. Would anyone have one in Mt Isa? (Met with laughter). Temporary solution: $22 fan bought at Autobahn to circulate some air. Would have been okay if the front flaps were still operational on a puma!
    It seemed to be blowing hot air particularly from the driver's side vent at first, which made me think after reading some threads on here that the condenser may not be the issue. However, my mechanic has just confirmed it is the condenser, which is not a cheap part at $2550 for genuine or $1650 for Heller. Apparently the bullbar has to come off for access and I'm considering whether to put it back on as it is a bit heavy and the alternative to so do something about the suspension.
    Second issue, I heard a wind noise doing 100km/hr between Barcaldine and Jericho and saw the amber engine warning light. I had a look and couldn't see any cracked or broken hoses or any leaking fluid. Contacted the RACQ. They got a chap from Jericho to contact me. He wanted to know what sort of engine it was and then said he didn't have the computer to read what was the fault and he'd have to get back to RACQ. Eventually a chap from Barcaldine came out with a flatbed. Couldn't see anything wrong and flat bedded it back to Barcaldine. Endured conversation on the way back (nice fellow) about how easy Toyotas are to work on... 24 hours later, despite having the fault cleared by the computer, its still tripping the warning light and going into limp mode. No crack in hoses etc visible. Local guy stumped. Put him on the phone to my mechanic. Ultimately the local guy concludes that without a 'smoke machine' he can't work out where the issue is and he doesn't have time to pull everything apart to work it out.
    So, courtesy of RACQ, it was flat bedded back to Brisbane to my mechanic at no cost to me, and the RACQ also put my son and I on the Spirit of the Outback back to Brisbane (also at no cost), which wasn't a bad way to end the trip.
    It has taken a few weeks, but the mechanical issue has now been fixed for a grand total of $328.75. It was the throttle body hose.
    Now, I'm pretty philosophical about this; I'm just glad this didn't happen while in the Simpson desert. There is simply no way you would get over those sand dunes in limp mode. It also makes you wonder how such a little thing can bring a trip to an end, and how one might be able to get this diagnosed and fixed without having to send the Defender back to base on the back of a truck?!
    Torres Straits
    In your particular case
    No ECU reader will locate the actual fault, at best you’ll get a code
    For loss of MAP (but you don’t need a computer for that because you could hear it)
    Diagnosis was made by you - induction air leak.
    Good ol process of elimination will eventually find the air leak... start at the turbo and work towards the inlet manifold. but you WOULD need a device to clear the fault once fixed
    I’m guessing the bush mechanics couldn’t be bothered following the induction piping as opposed to any particular difficulty in doing it. The induction plumbing on one of their beloved Toyota 1VD eights would give them apoplexy if they were struggling with a tdci! Never mistake competence or lack there of for motivation.
    The fact it only cost $300 to fix means a motivated mechanic found the leak in minutes then fixed it.
    Glad your back safe. As Tombie says on here, vehicles with ECUs should have a means to Read and clear faults in their spare parts toolbox no different to a spare air/fuel filter and cable ties.
    S
    DiscoMick Guest
    Sorry to hear about your problems.
    I like to tell mechanics its a Ford engine and gearbox, seems to make them much happier.
    Jun 2014
    Dubbo
    You could tell them its a two stroke rotary opposed piston engine and they'd believe you. Probably wouldn't encourage them to have a go at fixing it though.
    I had a limp mode incident last Christmas in the High Country, which could have ended the same way. Fortunately I had my IIDtool with me so was able to read the fault code and work out what had happened. Then I could clear it and continue on. Without it I’d have been limping out with great difficulty then flat-bedding it to Albury - on Boxing Day.
    I think having the ability to read and clear fault codes is vital if going remote.
    And, yeah, isn’t the road between Dalhousie and Mt Dare in a shocking state.
    Jon
    Brisbane,some of the time.
    Quote Originally Posted by jon3950 View Post
    Jon
    It was three yrs ago,and the road to Finke was worse
    Jun 2008
    Drouin East, Vic
    A code reader is more necessary than a second spare tyre these days for remote travel. Some ability to interpret the reading to locate a problem is also helpful, but mostly the ability to clear a limp mode.
    I had a stone go through my aircon condenser not long after buying the vehicle; genuine condenser was quoted in the thousands, aftermarket suppliers did not list one...HOWEVER I discovered that the late model TD5 defender has the same condenser and the aftermarket suppliers have that for a few hundred dollars. Ask a Natrad place to look up the TD5 Defender condenser, there will be a couple of different types and you want the latest of them.
    Crafers West South Australia
    Was bad in 1996 too. Blew a shocker in the P76 but I carried a spare so no biggie.
    Dec 2014
    We had to limp out of the Simpson Desert in July this year in the D4. Went into limp mode a half day into the desert. Used the IID tool but no faults logged. Tried clearing regularly but would drop into limp mode within 50m. Also tried total battery disconnect, wait 30 mins and reconnect. Same event, no faults logged, even though in limp mode. Eventually after many hours of climbing dunes extremely slowly, we were on the flat into Birdsville when the error codes appeared. Took it to the mechanic as we could see nothing obvious. Neither could the three of them, in consultation with an LR specialist in Brisbane. Flatbed home for the D4 and flights for us. Turned out to be a seized CSO valve.
    Sep 2009
    What is a CSO valve?
