Front Suspension Issues - what do you think.
Well my RRS has now done 160,000km - within the last 15,000km I have replaced the front disks (PBR) and pads, put on new Nitto Terra Grappler ATs and had a full wheel alignment. The front end is all original and for a little while the suspension arms have been making a bit of noise but not too bad mainly on poor town streets rather highways or offroad.
When I got the new tyres, the balance was not the greatest but the Nittos have lots of casting dags on them so I decided to leave the balance as was and see what happens.
For the last two months I have been doing lots of kms and not have had the time to have the car off the road for maintenance other than changing the engine oil and filter.
Over the past few weeks the balance seems to have got worse at around 90kph but fine at other speeds then when braking from highway speeds there was a noticeable shake from the front end and the steering wheel until speed slowed a bit and then ok - a bit like the front end death wobbles at speed in a Series 1 with dodgy swivel pins - but no where near as bad. Around town braking, steering and the front end all perform perfectly.
On Thursday I had to go to the coast and the car was fine until I was going down Macquarie Pass where the wobbles got really bad when braking for the bends - in fact a loud knock from the front end was audible matching the shaking of the wheel. At the bottom of the pass - all gone and on the straight and level no issues even with test braking from 100kph.
To start the diagnotic process I got a front wheel balance yesterday and that improved things a little but the wheel shake is still there sometimes.
So to diagnose
Is it - wheel balance, warped disks, the worn suspension bushes (upper and or lower), worn upper/lower king pins, steering tie rods or a combination of the lot.
WHAT DO YOU THINK?
This is what I think.
I know the lower suspension bushes are worn and the balance on the front wheels was not good. The brake disks are new so unlikely to be warped. The problem only shows up when braking at higher speed or under heavy load and is like the series 1 death wobble - so I think my suspension rubbers are worn (known) and when braking the wheel balance issue is causing the whole lot to be loaded up and magnifies the movement in the front suspension system, in particular the upper and lower kingpins causing the audible knock. I dont think I have a brake warp issue as the issue is not consistent across the speed range.
So - wheels are now balanced, brakes are probably fine - do I just order new Dephi lower suspension arms with a new king pin from Advanced Factors and get a new top kingpins as well. Are steering arm ends also likely need to replaced.
The car drives fine with no noticeable issues at all around town - in fact the rear roll bar rubbers back more noise than the front lower suspension arms.
SO WHAT DO YOU THINK?
