Results 1 to 10 of 11
Thread: PVC conduit cutters - a useful tool for more than just conduit
    Geelong, VIC
    Bought a pair of ratchet style cutters for plastic conduit from Aldi a couple of months back. Cost around $15 from memory.
    I picked them up as an impulse buy as conduit is one of those PITA things to cut with conventional tools. Either you're messing around with saws or struggling with a stanley knife etc and risking injury.
    Likewise with poly water pipe.
    These things work well on conduit and the poly pipe, but I've also found they are great for vehicle hoses too. Heater hose, fuel and oil hoses (basically any hose/tube long as long as it isn't metal reinforced).
    As an example, I was removing the turbo off the county last week and the oil drain hose was well stuck on its fittings. Rather than risk losing skin trying to pry them off with a screwdriver or slipping with a knife I just cut the hose in the middle with the conduit cutter and sorted it out once on the bench with decent access.
    Likewise when installing the new piece of hose. Normally I'd put one end on, mark the other, remove it and cut on the bench. With the cutters I could just mark the end with my thumb, then cut while it was still on the vehicle.
    No drama, no injury.
    Hope this helps someone - happy cutting!!
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Jul 2015
    Taupo NZ
    Quote Originally Posted by steveG View Post
    Steve
    Is this the sort of thing?
    Yep. I bought an Aldi one, too, a few weeks back.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    Yeah, very handy bit of kit. Wouldn’t be without some. 👍
    May 2003
    On The Road
    On the better quality ones the blade is replacable too
    Brisbane,some of the time.
    What,it wasn't faulty,and hasn't broken or fallen apart yet?
    I got someone else to select it from the pile.
    Geelong, VIC
    Quote Originally Posted by Gordie View Post
    Yes, that's the type.
    Steve
    Feb 2013
    Ballarat,Vic,Aus
    You mean everyone doesn't just use a hacksaw blade and do a really nice crooked wonky cut ...... Must only be me then
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    NSW far north coast
    Secateurs (Bahco) are what I use for beer plumbing and small diameter small hose.
    They cut really neatly.
