Have you recently checked/replaced the lower control arms?
Once I replaced mine I felt a big difference.
folks,
my old 2007 D3 with 240 though on the clock i starting to feel a bit loose in the seering, its had wheel align done not that long ago without much improvement.
I'm starting to suspect steering rack & ends as getting a bit sloppy and possibly the lower steering wheel shaft too.
Anyone done a replacement?
How difficult etc? Can't find much online about doing them.
ta
P
done about 20 thou ago though I have noticed the drivers side clunking a small amount when I back out of the drive.
 TopicToaster
						Subscriber
						TopicToaster
						Subscriber2010 TDV6 3.0L Discovery 4 HSE
2007 Audi RS4 (B7)
suspect it could be the lower shaft U/J. My steering has become heavy and does not return to centre like it used to.
DISCO3.CO.UK - View topic - Steering stiff - New lower column fitted with guide
Still thinking the tie rod and ball ends need to be replaced. As for the seering rack I am not sure and don't know enough about the symtoms this would cause to make call on it.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberMy prior D3 steering rack was replaced at about 300,000km I think. By Ritters in Melbourne
I'd like to do it myself if possible but seems to be a bugger of a job.
