Results 1 to 10 of 19
Thread: Disco 4 CV joint dead
    Aug 2016
    Torquay
    Howdy, holed up in Mansfield waiting for flat bed back to Torquay. Got a flat bed here from sheepyard flat after being towed back from zeka spur by the guys I was touring with.
    Any rough estimates in what it’s going to cost to fix.
    Frustrating as was we weren’t doing anything particularly hard when the dreaded bang of the CV joint interrupted a planned 4day adventure in the vic high country...
    Any advice appreciated
    Aug 2016
    Torquay
    Can I get stronger cv joints installed for off road for example?
    Aug 2016
    Torquay
    BuggerDisco 4 CV joint deadDisco 4 CV joint deadDisco 4 CV joint dead
    Oct 2012
    Do you work in super extend mode a lot? Do you have Llams?
    Aug 2016
    Torquay
    No never
    NSW SW Slopes
    Front or rear? If rear, does your D4 have an e-diff? Rear CVs are bigger when an e-diff is fitted but can still be broken. If front, was it the RH? RH will pull apart at off-road height + full lock + heavy right boot.
    Mar 2012
    melbourne
    What exactly were you doing when it broke?
    I have never broken a CV , touch wood NOW, but I never use full lock at full articulation and the skinny pedal at the same time. If at full lock or even close very little accelerator and I never steer left and right like a mad man to try and find traction, if its that slippery I have a winch and recovery gear.
    Am very interested in what made it go and if it is a very weak unit or no offense but the nut behind the wheel
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Aug 2016
    Torquay
    No offence taken. I drive conservatively. In fact, I was just climbing a reasonably steep, and slightly bumpy dry 4wd road. Not slipping. Going straight ahead. would describe the section as medium grade tops. So definitely not full lock, and not trying to find traction.
    Can they wear over time or do they usually require the type of driving you describe to fail?
    NSW far north coast
    It's an overload/fatigue failure, the overload/damage has been done in the past and it's finally let go.
    Aug 2016
    Torquay
    Maybe so. I got the car with 40k on it (previous owner used it for city driving. Have done 60k since. Off road some of that time. Only time I can think where I might have over loaded it was a climb out of a river crossing in the vic high country in January this year. Slippery, heavily rutted, and steep, I reckon I might have put too much steering in. I remember thinking that was stupid- brain fade. Thought I’d dodged a bullet at the time. That might have done it I suppose. Paying the price 10 months later?
