Thread: The P38 and home gadgets...
    Nov 2008
    Bruthen, Eastern Vic.
    I found the battery on the P38 almost discharged a week or so ago.
    Being new to the vehicle and after reading a few posts on here about mysterious battery discharging I have been checking the battery regularly. Happy to see that the normal discharge has been about 20mA. Happy with that. The EAS relay has an isolating switch.
    So... suddenly the discharge is 550mA
    Drops to 20mA after about 3 minutes and then back to 550mA immediately.
    Looks like BCU waking up - what on earth can be doing that? Car locked, same. Car unlocked - same. Key fob batteries out- no difference.
    My nearest neighbor is 5km away so no stray radio signals around, or so I thought.
    Then after a few days of this I remembered it seemed to start about the time I installed one of those meter box power monitors, unit attached to the meter sends a signal to the indoor display every 30 seconds. AND on 433mHz.
    Out with its batteries - problem gone.
    Looks like the monitor has to go.
    Geez I really like this P38 but I never had these problems with series Landrovers
    Terry
    May 2003
    On The Road
    Bloody modern tech!!
    When I used to drive mine to work (signal box on NSW railways) at some sites. e.g., St Marys (NSW), the key fob would not lock/unlock the car. I guess the local RF from the on-site transmitters would affect the Rangie.
    Feb 2013
    Gosford, NSW, Australia
    Hi
    Martin Cox has a solution (apart from replacing the receiver)
    P38 RF Receiver Filter
    Steve
    Jan 2016
    Netherlands
    well dang, I always though the battery drained on these quickly but this explains a thing or two. I usually leave the key in the ignition though (yes I can do that down here) so I wonder if it still activates then...
    -P
    Nov 2008
    Quote Originally Posted by prelude View Post
    -P
    Seems any RF at around 433mHz will wake it up to check if its being requested to do something. Stays awake for about 3 minutes then goes back to sleep. If the RF is still there it wakes up again and......then flat battery
    Terry
    Nov 2008
    Quote Originally Posted by TheTree View Post
    Hi
    Steve
    That filter probably wouldn't work because the RF signal from my gadget is already in the frequency range that the BCU is expecting from the key fob.
    Terry
    Feb 2013
    Quote Originally Posted by rover-56 View Post
    Terry
    Martin is very approachable, so if you are interested I would send him a message and ask him if it would help your issue
    Steve
    Nov 2008
    Steve
    Thanks Steve, but I have solved the problem by giving the monitor to a friend. No she doesn't have a P38
    Terry
    Feb 2013
    Much cheaper option
