Results 1 to 10 of 16
Thread: Heater valve possible malfunction
    Aug 2012
    Adelaide
    So, after freezing driving the perentie home from Minto auctions and not thinking the heater was anything to write home about (lets agree it isn't) I now find myself perplexed. I'm now in Mackay again and it's getting rather warm so windows are living in the shed and the canvas is rolled up, vents permanently wide open, I reach down to the "fan vent" and can feel warm air coming through - warmer than I think it should be. I've replaced the foam between the plastic vent box thing and the blower housing to keep the hot engine air out of the mix but it hasn't made any real difference. I was fiddling around under the bonnet and I see that the heater lever can move maybe 4 or 5mm further in it's stroke before it hits the 'stopper?
    would adjusting the cable so it's hard on the 'stopper? help? or maybe the heater valve is dead? I'd just bypass the heater completely but it'd be nice to keep it working if possible since it's there already and I'm keen to do some travelling to colder parts.
    Mar 2007
    Canada
    Here is no heater valve. It is just a flap. Adjust it so it is tight. The heater adjusted and setup properly should work as well as any other car. The sealing foam falls put over time and needs to be replaced.
    in the wild New England, NSW
    There are alternatives debruiser if you need to have the heater NOT functioning for a while.
    1. short circuit the heater pipes from the heater unit
    2. fit a valve like in the civvie version of the 110
    3. place a manual ball valve in the flexible parts of heater pipes
    4. sell me your heater unit for my County rebuild
    Hay Point
    What Red90 said. The flap has a ****ty old foam strip for a seal, it falls apart over time.
    Cheers......Brian
    1985 110 V8 County
    Aug 2012
    Adelaide
    I'd contemplated putting a ball valve in the coolant line but then thought that would suck turning it on and off blah blah blah..... better to fix it properly if possible.
    So this foam seal thing is inside the heater box?..... I shall have to do some research and then build up to pulling it apart.
    Cheers fellas.
    DiscoMick Guest
    I just replaced my heater valve in the Puma because of this problem for US$28 from China. It's a Fiat Peugeot part.
    Get a mechanic to look at adjusting the moveable arm on the back of the heater valve attached to the cable from the dash dial. Mine was stiff and needed oiling. You may need to disconnect the cable and adjust it so the valve closes completely.
    There are pics in my thread in Member's Rides. Hope that helps.
    Hay Point
    Quote Originally Posted by debruiser View Post
    Cheers fellas.
    Yes, inside the heater box. Pretty easy to pull apart. A ball valve in the inlet pipe is the go.
    Cheers......Brian
    1985 110 V8 County
    Oct 2017
    Phillip Island
    So run the ball valve as a heater bypass or just block the thing off all together?
    DiscoMick Guest
    Like this?
    Make sure the valve can cope with 100 degree heated coolant. This is from Pirtek.
    Crafers West South Australia
    Rather than fitting a manual ball valve, just fit a universal cable operated valve that can be opened and closed from the cab with a choke cable. Example:
    Heater Tap Valve Universal Type Car Hot Rod 16mm (5/8") Cable Type Inline | eBay
