Results 1 to 10 of 19
Thread: D3 ticking noise in sync with wheel speed
    Mar 2011
    Balbarrup WA
    Have been trying to locate cause of a "ticking/tapping" noise that sounds like it comes from front wheel and varies with speed of travel. faster I go the louder and more frequent the "tap" becomes.
    It is the sort of noise one usually associates with a rock or a screw in the tread, but have not been able to find anything in the tread.
    The sound has slowly become more noticeable/louder and has persisted for past month.
    Local service person also had a drive, can hear the sound easily enough, but cannot suggest what sound might be coming from.
    Cannot see any loose/torn CV boots, nothing seems amiss on axle/drive shaft area.
    Have jacked up wheels, checking if bearing wear, does not appear to be related to bearing.
    I wondered if something might be touching in hub area (ABS sensor rubbing, but that seems unlikely).
    The noise "ticks" in rhythm with wheel speed, not a scrape like if disc pads rubbing, or a stone caught. I am thinking front wheel area, but could always just as easily be rear wheel.
    So any suggestion where I might go exploring for noise?
    NSW SW Slopes
    Fit the spare then move it around to different corners to see if the noise stops. If the head has worn off a screw then it might still tick but be difficult to spot.
    Mar 2011
    Balbarrup WA
    Unfortunately that looks like what I am having to go and do (after I do a very thorough check around front stub axle drive shaft area with front wheel off).
    Not losing any air, so puzzled as to what it might be in face of nothing obviously stuck in tyre.
    NSW SW Slopes
    I assume that you have checked the wheel nuts.
    If the ticking occurs with every wheel rotation then a CV joint could be causing the noise but swapping wheels is easy, albeit a little time-consuming of having to swap 3.
    Mar 2011
    Balbarrup WA
    Unhappy
    Yep, have done all the obvious like wheel nuts, and pretty certain not the CV's, because it is only in straight lines, but no noise when turning corners (which are done much slower of course).
    Will just have to pull off the wheels and go have a big sticky beak.
    Jun 2010
    Central Coast NSW
    I've had the rear hand brake cables not reinstalled correctly after some work and the wheel weights had worn through the outer sheath. It got worse turning one way and disappeared the other way.
    I know you said you think its front wheel but might be worth checking.
    Mar 2011
    Balbarrup WA
    Quote Originally Posted by Disco-tastic View Post
    Thanks for that, I have been thinking it could be something odd like a weight that has moved and is just touching (something), but figured it would just wear away. It started after I had 4 new shocks and air legs installed, so I'm wondering if something a bit out of line that might be touching. looks like I will have to get it up on stands, off with all wheels and crawl all about, because it seems to be nothing of the usually obvious.
    Sep 2014
    Baldivis WA
    Just a thought, in case you’ve had the brake rotors off for the strut replacement, there’s a countersunk bolt that holds the hub of the brake rotors in place. Perhaps this hasn’t been tightened up correctly and is sitting loose. It’s captive behind the wheel when it’s mounted so it can’t fall out, but it’s off centre. Could be rattling around?
    Mar 2011
    Balbarrup WA
    Chasing that tapping noise
    Quote Originally Posted by Eric SDV6SE View Post
    So far have pulled off all wheels, no obvious tyre distortions, picked out anything embedded in tread, nil screws nails, limited small stones, and undone discs on front (looking for anything rubbing), checked clearances on backing plates, drive shafts, looked for any shiny bits that might suggest touching.
    Nothing showing thus far, and the tapping is slightly more pronounced?
    I'm going to swap over a couple of my spare wheels to the front and see if that changes anything....
    NSW SW Slopes
    Have you checked around the tail-shaft?
