Results 1 to 10 of 14
Thread: 285 tyre's
    lowy Guest
    285 tyre's
    Hi all ,
    I know a lot on here have 255\85\16 tyres on their perentie's , But anyone have 285\75\16
    Yes I agree standard aren't bad , But not for my application , I tend to doddle along around the lakes here in Tas , As soon as you break the crust ,If there is one , down to the diff you go . I find wider tyres a bit better in this sort of situation .
    Anyway just thought someone out there would run them ?
    Feb 2005
    I always thought a taller tyre gives you a better footprint than a wider tyre.
    Although it seems most go wider as going taller buggers up ya gearing
    Mar 2018
    Tasmania
    I actually just whent back to taller (255/85/16) from wider. (285/75/16) I think performance wise they really are on par but to make 285s work well you will want some decent offset wheels- I'd say 0 or -25 and you will also want extended flares. Of which I have some for sale on gumtree in Tasmania. The 255s will work with less modifying, are easier on steering components and throw less mud alll over your car.
    lowy Guest
    Maybe I should go to the 255/85/16 ...
    another reason for the 285's tho .....If I read the Tasmanian rules correctly ( maybe not)
    It said a 4x4 tyre could be 50% wider than the factory fitment and no bigger that 50mm in diameter than stock .
    going by the tyre caculator , 255/85/16 are about 53 or 54 mm larger diameter than the stock 7.5r16 but 285/75/16 are about 47mm
    lowy Guest
    I think your right , It's just that the 285/75/16 are close to the same height ? But still a fair bit wider
    No power steering could be a worry tho
    Mar 2007
    Canada
    A 285 will allow you to run at a lower pressure than a 255. The lower pressure will give you a larger footprint and better floatation.
    Aug 2012
    Adelaide
    I've run both sizes on my Puma 90 (yes I know that's a little different, but bear with me for a second!)
    As a comparison between 255 to 285 sizes: just as a note - i have the 255s on deep dish HD rims and the 285 on 0 offset dynamic style rims
    - 255 are probably mildly taller (I dont really notice the difference)
    - 285 you can feel a noticable difference in power - as in a bunch less. (I have KM2's in both sizes)
    - 255 are easier to turn the steering, and on a perentie where steering is already heavy I think 285's would be terrible.
    - 255's give better fuel economy. it's not a lot but there is a difference.
    - 285 LOOK great.
    - 255 at the time I priced them were $80-100 more per tyre. (hence why I have a set of 285s.)
    - 255 although don't look as angry etc - they look pretty stock, so I think you'd get away with the size difference before 285s that stick out!
    Not the best pics but just for an idea - Pic 1 is 255s. Pic 2 is 285s. Pic 3 is 255's on the Perentie.
    lowy Guest
    Quote Originally Posted by debruiser View Post
    - 285 LOOK great.
    Thanks for the comparison , Any idea what offset the HD rims on the perentie are ?
    I understand why the majority go for the 255 now
    Thanks again .
    Aug 2012
    Adelaide
    I think they might be ARN1534, off a really early 130. I had a quick google for you but I can't find a conclusive answer to the offset sorry.
    I did find this:
    Land Rover Wheel Specification
    and it suggests a 20.6mm offset. which compared to the 33mm of my D90 sounds about right....
    Mar 2018
    Tasmania
    They are just about positive 20
