The after video is quite the sight,,,, why wasnt the driver in the cab? what can he be checking on a 260 odd car consist? no deadman switch? just how fast can a train that size "roll away" ?
This could be an unfortunate world record that reads like a movie script.
This train wasn't intended to be driverless, but it got away and it was on a downhill grade.
It travelled over 90km reaching speeds up to double of that approved until it was deliberately derailed by crossing a set of loop points - hundreds of wagons and kms of track destroyed, tens of thousands of tonnes of ore dumped.
A problem that probably would not have occurred if single driver crewing hadn't been forced by the company. Think of the $ that would have been saved if a second crew person had been on board.
Well done the bean counters !
BHP runaway iron ore train left a twisted wreck after derailment stopped it reaching WA town - ABC News (Australian Broadcasting Corporation)
'97 to '07. sold.![]()
I find it amazing that they could derail the train remotely but not apply the brakes. Maybe they did and that was the result.
1. word has it that driver had left cab to apply manual brakes on wagons (how many I do not know - but it would take a whole shift to apply them all), other assistance was sought but they ended up applying manual brakes on the wrong train
2. "deadman switch" doesn't work in this condition
3. over 140 kph on the downhill 1:50s I believe - that would have been something to see!
I have to agree about the Bean Counters, the cost of this disaster converted to wages would have fed a few mouths for long time.
Why didn't it have a "Deadmans" control switch?
I thought all locomotives had them and if they were not responded to in a given time the brakes activated.
Especially locomotives that have single crewing would require them for sure.
Cheers, Mick.
1974 S3 88 Holden 186.
1971 S2A 88
1972 S3 88 x 2
1959 S2 88 ARN 111-014
1959 S2 88 ARN 111-556
REMLR 88
1969 BSA Bantam B175
I just can not understand in this day and age of safety devices it occurred at all.
In the cabin of a diesel loco I have been in the safety deadman devices gave the driver the ****s.
I don't claim to be up to speed on these things.
Why would you need to manually wind on brakes on a modern train with all the wagons connected up ?
Why wouldn't the brakes be auto applied soon as the driver stopped operating the dead man in the cabin ?
Why wouldn't the brakes be auto applied if the train rolled past a stop signal ?...…….the average suburban train in Sydney has this feature since the 1930s ???????
With remote control tech...……..why a system was not installed so the train could have brakes applied remotely or dynamic braking applied ???
Even if there is a fault with the brakes...……..should they auto apply......ie air loss ?????
Ron
I don't know the detail for bhp trains, but just for example in the latest local computer controlled trains, if the computer malfunctions the manual brakes need to be applied before it can be switched off & on to reset it (!). Just applying the manual brakes to every 2nd wagon in a 82 -90 wagon coal consist and then releasing them can take most of a shift for a two person crew - the crew member driving doesn't leave the cab, but they can swap tasks.
The "deadman" (vigilance control) is only going to work when drive/power is engaged.
In a statement released by BHP on Thursday, the company said that as a result of the preliminary investigations it had put additional interim safety controls in place.
Why would they need to do that if everything was hunky dory in the first place? Scapegoat springs to mind.![]()
