Sure we like info on stuff like this
Hi guys,
I thought I would share this...I made a simple upgrade to the interior which I've only seen on a 2013 sport. Leds that shine down on the door pulls inside. Controlled by the dimmer switch.
Let me know if you want more info on how to install etc. Takes 5mins per door.
Jeremy
IMG_20181109_165213.jpgIMG_20181109_165158.jpgIMG_20181109_165141.jpgMVIMG_20181109_170744.jpgMVIMG_20181109_170754.jpg2012-range-rover-sport-for-sale-ct-land-rover-dealer-connecticut-15-728.jpg
 Wizard
						Subscriber
						Wizard
						SubscriberSure we like info on stuff like this
Hi Jeremy
My 2011 RRS has standard LED lights over the door pulls but one has gone out and I want to fix it.
Do you have any tips for getting in behind the covers ?
2011 Range Rover Sport SDV6 Autobiography
2004 Freelander TD4 SE
1997 Range Rover 4.6 HSE
1994 Range Rover Vogue
Hi Dave,
It's easy to get behind, but you need to be careful not to break the clips on the chrome cover on the door.
The rear doors have 3-4 screws holding the door card on.
Once all removed you can start to pop off the door card - best to give it a strong tug at the bottom.
Once you have popped out all the clips, this should give you access to see the loom that links the LEDs.
It may be unplugged? Or if broken, the dealer can order for 100?
Pm me if you're in Melbourne and need help.
Jeremy
 Member
						Member
						Hi Dave, would love to add these to my car, I've got a 2008 TDV8. Would it still be compatible?
You'd have to check if your door pulls have little holes for the led to poke through..sorry not sure about this
