Results 1 to 10 of 20
Thread: Hole in the bottom of TDV6 air box, normal?
    Dec 2009
    Baldivis WA
    While having a poke about in my new to me MY14 TDV6 I noticed a hole in the bottom of the air filter box, see red circle hole in photo. This is in one of the two fixing points to the body. In the upper section there is a rubber one way valve type assembly, which makes sense. But no valve assembly on the lower hole. While I can sort of see why there would be a drain hole the lack of one way vale seems odd.
    So the real question is, is this normal?
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    St Helena,Melbourne
    4.28 MB
    The rubber plug has probably pulled thru and still attached to the inner guard.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2016
    I replaced my filter yesterday and yes, I have the same hole that goes through the bung that secures it to the body. I thought the same. I also questioned the value of my snorkel with a hole in my air box. At the moment I’m in deep thought, before I sikaflex it up. I like that it acts as a drain, but I dislike that it acts as a potential entrance.
    2007 Audi RS4 (B7)
    Dec 2009
    Baldivis WA
    The rubber bung that it pushes into is open at the bottom as well.
    Dec 2009
    Baldivis WA
    Quote Originally Posted by DiscoJeffster View Post
    I’m glad that it’s not just mine, but still puzzled why it’s wide open.
    Ocean Reef WA
    Mmmm. Must admit I've never noticed a bung and I've changed or cleaned my filter a few times....... so tomorrow I'll check mine as although I have a Safari snorkel I don't want water coming up through the bottom. Not that I intend doing and deep water wading any time soon but one never knows.
    AlanH.
    Sep 2014
    Baldivis WA
    I was going to silaflex up the hole in my air box too, as the original rubber one way valve had perished. Then I decided there must be a good reason for the hole, so with a couple of stainless washers, a stainless nut and nylok, plus a flexible rubber washer cut to size, I made a new one way drain valve. I also have the Safari RAI, I have found water at the bottom of the air box after driving in heavy rain so I wanted to be sure it can drain out.
    Aug 2015
    Wonder if there's a one way drain valve available that would fit that hole, would be perfect. I didn't notice it there when I changed filters either so assuming the bung is still in place.
    Haha, I must have skipped over Eric's post. Nice idea Eric. I wanted to fit one to the original spare wheel winder hole, so I could put a water tank above it.
    Sunshine Coast - Queensland
    Snorkel Fitted?
    I read somewhere in a snorkel installation manual - or was it on a you-tube install video - that the hole is to be filled - I think they like to totally seal the airbox to achieve submersion success??
    Mar 2016
    My safari instructions didn’t include that I don’t believe.
    2007 Audi RS4 (B7)
