Results 1 to 4 of 4
Thread: Coolant Bottle cap failure
    Ean Austral Guest
    Angry Coolant Bottle cap failure
    Gday All,
    not sure if this is common or not - don't seem to have read about it but had mine fail and could be nasty outcome as you loose coolant . Lucky for me the message centre warned me both times . Only needed about half a litre to top up each time but I managed to pull over straight away as soon as I seen the icon come up. The surprise was how much came out when I finally turned the car off .
    I replaced the coolant bottle about 12 months ago but they don't come with a new cap , old one screwed down fine and has been good but the cap ended up not being able to screw down tight and actually came loose whilst we were driving . I had to top it up and use some tape to hold the cap on as best I could till I got to a van park to inspect things closer .
    Justin Cooper organised me 1 overnight and things seem ok in the 500 odd Ks I have done thru the Tassie hills since it happened.
    Moral to the story - fit a new cap when you fit a new bottle as you will be surprised how quickly you loose coolant from a faulty cap. Luckily for me it happened where I could source 1 easily and quickly thru Justin. A plug for Justin as well for his help and fast delivery.
    Cheers Ean
    May 2003
    On The Road
    So, you're in Tassie now??
    Ean Austral Guest
    Trying to be stealth Pedro so happy for this to be worthless at this stage.
    cheers Ean
    May 2006
    Yack
    2.78 MB
    Had exactly the same problem half way along the Anne Beadell a few years ago - thought the HG was going for a while.
    One of those rare occasions where the simplest fix is the right one.
