Chinesium bearings..?
When you rechecked the preload, did you remove the cv and swivel ball seal as these would create friction and give a false value.
If they were timken bearings, too loose may have caused chattering and hurting the race.
But too loose also causes the swivel seal to leak.
Not much help from me.
				'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
