done by this mob
Retter Manufaktur Kft - Pascal Turtscher
Not much gives it away ! Vienna, Austria.
55kwh of Tesla modules , 120km range ( mine uses 30kwh / 100km)
still has gearbox & transfer case, no motor / controller details
done by this mob
It might be sacrilege (and apologies if it is) but if I had the $$ and space to I'd EV one of these;
Amazing
So an EV conversion will most likely become common place? ...what is the consensus on what it might cost for an EV conversion? And when will it become an affordable, easy option?
...We’re about to go from being concerned about all the new electrickery and it’s reliability, to nothing but ekecktrickery! What will EV reliability be like compared to ICE?
Electrics are ULTRA Reliable, no cooling , exhaust , alternator , etc etc . Brakes will be far more reliable and last magnitudes longer because regen does nearly all of the braking. Friction brakes only needed to come to a complete stop or hold on a hill.
The motor and controller should last several lifetimes so long as not overclocked by "performance tuners" ( Tuners are now getting upwards of 2000Nm out of Nissan Leaf motors) LiFePo4 Batteries will last upwards of 300-500,000km if you don't abuse them . Better battery tech coming along soon.
As for all the useless added on crap that manufacturers think people think they 'need' that will be the same reliability as for any modern car & then there is bound to be built in obsolescence.
Yeah, but can you push start them when the batteries flat?
The alternator is usually replaced by a dcdc charger, how much more reliable is that system - all depends
On a diesel, the fuel pump could fail. On elec the charge controller could fail.
If you put a IP rated good quality e-motor in an old landy, with a simple battery and charging system, it should be as reliable as a well maintained diesel, but with far less servicing required and cheaper to run.
But set it up like a Tesla with automatic smart internet connected everything and you are asking for trouble.
the cost difference would be in the batteries. The more range , the bigger the traction pack = higher cost.
12 months ago I paid $392 per kwh of Prismatic LiFePo4 battery storage , Todays prismatic rate is down around $300 ,
A Tesla uses about 20kwh per 100km so if you want 500km range you will need 100kwh of battery = $30,000 of battery
Obviously Tesla make their own batteries and are a LOT cheaper than Prismatic cells that I bought .
My Landy conversion gets about 30kwh per 100km , I have 28.8 kwh of battery = 96km range ( I paid $11,000 in batteries, my total conversion cost was about $22,000)
So its not cheap ( but a lot cheaper than a $45,000 LRA Chevy LS Conversion) and your not going to do it to a paddock basher, You will only do it on a car you love & will keep for the long term.
Wait a few years till theres a supply of smashed Nissan Leafs to use the Motors & batteries from. (or import them from Japan now)
There are no moving parts in a DC -DC converter no reason that wont last for ever, I bought 2 because they were so cheap but know I'll never need to replace it.
A quality A/C electric motor will last millions of km or a hundred years with zero maintenance, A well maintained diesel by definition needs regular maintenance (and repairs as necessary)On a diesel, the fuel pump could fail. On elec the charge controller could fail.
Exactly , you don't need any of that smart rubbish in any car IMO,
The only problem I can see , and its a likely scenario , what if your charging & the power line gets hit by lightning.
Cheers GB, very helpful.
So theoretically battery tech will become much more affordable as the market increases as will electric motors...making converting vehicles to EV with a decent range a financial reality down the track.... Many spend $20k or more on upgrading components / accessorising their 4x4's now anyway.
How much does a new Nissan Leaf engine cost and what battery does that come with? ...would that be a realistic option for a non-tech minded person to have their Defender or Discovery converted EV now? Or would you wait a couple of years?
