My brother did his. Left the Territory injectors. Had to change the pump. Also has different injector rails
Hi all, I am into a body off engine swap on a Discovery 3 2005 model. I have the engine out am up to changing parts from the old engine over to the Territory one. I am un-shore if the injectors and fuel system need to be swaped out. Daz from Aztec 4x4 mechanical thinks they might be compatible but hasn't tested this.
Has any one done a pre 2007 Discovery Territory engine swap?
Any help appreciated
Bob
It doesn't leak oil, Its sweating power
There is a write up on here somewhere describing what needs to be swapped over. Have a good search.
2002 D2 4.6L V8 Auto SLS+2" ACE CDL Truetrac(F) Nanocom(V8 only)
There's this thread, maybe some info re the pre 07 swap?
Some info but didn't have time to read the entire thread
A Comprehensive Guide
Lemo
I have swaped out the fuel pump and rails. I am un shore if the fuel return sensor at the y junction in front of the fuel filter and hoses have grey mesh coverings, needs to be swaped as well ?
Bob
A successful engine swap. Thanks guys. Patience will get you there.
