Results 1 to 2 of 2
Thread: HPFP belt changing instructions PLEASE TDV6 D3 2005 model
    Banjo Bob Guest
    I have my engine out of my Discovery 3 2005 model and need to swap out the HPFP. Does any one know how to remove and replace the belt. I am using a Territory 2.7 TDV6 and the HPFPs are different. Any advice on removing the pump will be greatly appreciated.
    NSW SW Slopes
    This is an extract for a 2.7 from the D4 WSM. Some other referenced sections may also be needed.
    Note that a new tensioner will be required.
    Attached Files Attached Files
