Results 1 to 4 of 4
Thread: Replacement bits & ZF service
    Nov 2017
    Adelaide
    HI Guys,
    Ive a 2011 RSS TDV6 3.0.
    Last workshop to work on it had not replaced some hoses in their correct clips & places which has caused them to rub through themselves.
    Ive bought a workshop manual & checked out Rimmers and unable to find any replacement part numbers.
    Can someone point me in the right direction to buy the hoses please?
    Power steering, pressure side.
    AC hose, pressure side (I think) with the drier / filter in it.
    Thanks heaps.
    ps, is $910 normal for a ZF oil change & pan upgrade??????? Id taken the shielding off myself prior to do a fuel filter change.
    Towcar Guest
    I paid 500 at Pringles automotive in North Melbourne....I actually didn't ask what oil they use...but the amount of ZF gearboxes there made me feel comfortable. Theyreplaced with metal pan.. will do every 70xxxkms
    As for hoses...Rimmer brothers should help you if you have part numbers, email them. Although you might find the dealer not to be that bad on pricing for this stuff. I bought new seat foam for 100..
    Jeremy
    Check part nos. at Lrcat
    Use a PC, not an iPad, it doesn't seem to work properly with the iPad.
    Nov 2017
    Adelaide
    Hi Guys,
    Thanks for the links.
    So far ive found:
    AC hose: LR013861 (unknown on Rimmers)
    PS hose: QEP501720 (superseded by QEP500554) or QEP501840 (look the same) but mines a 3.0, not 4.2, 4.4
    Also im having difficulty reading the vins'. Mine is totally different to the on line references.
    Ill keep poking around on the forum......
