Results 1 to 10 of 20
Thread: Diesel Gen Pod for off grid EV Charging
    Jul 2011
    Yarrawonga, Vic
    Interesting the Tesla Club would come up with this idea , Thought Solar arrays might be more their style,
    EV charging with diesel powered ChargePod skid – a solution for locations with inadequate power – Tesla Owners Club Western Australia
    Going to need lots of them given most of Australia is "Off Grid".
    Aug 2010
    Sunbury, VIC
    The testing methodology is flawed IMO. While they went to great lengths to calculate fuel usage per vehicle, which is valuable data, when working out the entire cost, you have to factor in purchase cost and maintenance. Given the engine would need servicing every 250 to 500 hours depending on how the unit is configured, and these will be in butt **** now where, the costs involved are significant. As you said, why not a large solar array and battery bank? Would have thought the cost would be comparable but even if it was more expensive with lower running costs and much lower and cheaper maintenance it would play out in the end.
    Crafers West South Australia
    It sort of makes sense if the Tesla Owners Club organised a club trip to a destination with insufficient power available. One of them would tow the genset out to the location for everyone to use. For dumping at remote road houses for permanent installation, not so much.
    Jul 2011
    Yarrawonga, Vic
    This bloke tows his own gen set .
    DiscoMick Guest
    How big a generator would be required to recharge an EV in a reasonable time, say overnight? Is carrying a typical generator and some fuel a realistic option for taking an EV into remote areas?
    Just curious...
    Jul 2011
    Yarrawonga, Vic
    Typically 6-8 hours .
    My Landy has an onboard 3.3kw charger , If my small 28.8 kwh pack was 80% depleted it would need 23kwh , Anything smaller than a "5KVA" Generator would be pushing hard to provide continuous 3.3 kw , would take 7 hours.
    Say a 100kwh Tesla with onboard 11kw 3 phase charger , was 80% depleted , needs 80kwh for full charge , would need a 15KVA generator & would also take ~7 hours .
    here is the Tesla Charging Options, could work for any EV of a similar capacity, IE Bollinger / Rivian
    Tesla Charging Options for Australia
    Jul 2011
    Yarrawonga, Vic
    Might be profitable to cruise the Iconic 4x4 tracks with one of these in tow.
    GENERATOR DIESEL 13.2 KW/17 KVA 3 PHASE SILENT GENSET | eBay
    Jun 2018
    Redesdale
    Isn't towing the genset around the country behind an EV to recharge your batteries at night a bit of an oxymoron?
    Wouldn't you be able to rig up some sort of greener generator for the same weight and size? Solar panels and battery bank or some wheel alternators or regen braking or some other crazy EV technology?
    And how much diesel would you need to carry? 5l per night? 20l per night?
    Cheers Jim
    Quote Originally Posted by LRJim View Post
    Cheers Jim
    Once you own an EV, there is no need for some mythical purity of intention. Just the questions, "how far can I push this thing?" and "how many peasants can I annoy or impress along the way?". Back in the Good Old Days teams did desert crossings with air or ground supplied fuel drops, "Damned new fangled nonsense, they shoulda stayed home or used camels" said the doubters.
    Aug 2010
    Sunbury, VIC
    Not with that particular unit - it would last 5 minutes on a trailer. Warranty of 1000 hours or 12 months. Our suppliers give us 12 month unlimited hour warranty - and that’s for hire machines - the most abused you’ll find. We’d expect 20,000 hours plus out of a machine like that, not uncommon for the Kubota powered small gens we have to go well over 30,000 hours without giving any grief. If they only warrant it for 1000 hours, it would be toast by 10,000.
    Back away slowly and don’t make eye contact with the salesman... 😉
