Results 1 to 10 of 14
Thread: D3. Wheel balance. Now EAS fault???
    Markus1 Guest
    Gday guys. Just had a tyre balance done. Straight away upon driving off up pops an Amber light suspension fault. Normal height only. Then after comes up with fault -will raise once cooled. Now the front is sitting down and neither front nor rear will raise or lower.
    I wouldn't have thought tyre joint can really screw it up so I'm putting it down to coincidence....hopefully...haven't had codes run.
    Left the car to cool.....didn't fix....unplugged battery.....didn't fix. Tyre guys don't know.
    Only thing non stock is steel rims so more weight on suspension but those have been on now for a few hundred km without any issues.
    Will get it read tomorrow. Just thought to ask for any ideas??
    Mark.
    Bunbury, WA
    Quote Originally Posted by Markus1 View Post
    Mark.
    Check all height sensors at each corner are plugged in and not damaged?
    St Helena,Melbourne
    1.13 MB
    As above possibly damaged a sensor by not jacking it correctly or over extended an airbag.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Ean Austral Guest
    Check they never damaged the air compressor..
    cheers Ean
    Markus1 Guest
    Thanks for replies.
    The airbags appear to hold pressure and the plastic cover of the compressor appears intact, unscratched etc. Not sure if that proves anything without taking the cover off and inspecting inside. Tomorrow's task.
    Not sure how they can overextend a bag????When the car rolled off the hoist it was down very low near access height which seems odd as everytime ive jacked the car off the rails the suspension is always left sitting really high.
    Just picked up my kid. The Amber lamp is gone but now system says 'will raise suspension when system cools'. Keeps saying that but will only occasionally raise up a touch really slowly. At one point I did get it into off-road height before foolishly dropping it to access. Now it's somewhere between access and normal. Stuck again. Ha ha. Crickey.
    I'd say this points to something compressor area related. Annoying that it happens right at tyre joint. I have to be careful about blame and jumping to conclusions. Car has 150k and is 10 years old. How long are these compressors good for?
    Mornington Peninsula
    Have you tried a soft reset? That is disconnect the battery and leave for 30 mins. Worth a try.
    2022 Defender D250 S being set up for touring.
    '83 RRC 2 door 300tdi on club plates
    '82 RRC 2 door almost finished on club plates (will always be nearly finished!)
    2013 Freelander (wife's)
    1994 Defender ute hopefully on club plates one day
    Ean Austral Guest
    If it's the compressor you will hear it running . Once it builds pressure it should stop but if it has a leak it will continue running till it gets hot. If you start the car then walk to the passenger side rear wheel you should be able to tell if it continues to run or not .
    could be coincidence, but they sometimes crack on the cap between the 2 airlines . Some soapy water sprayed onto the cap will soon tell you if it's leaking or not at the compressor end cap
    Cheers Ean
    Mar 2016
    My suggestion is that through the raising of the suspension to remove a wheel unfortunately you’ve gained an airbag leak. The compressor is endlessly running to maintain pressure and cannot, hence can’t get it up to normal height and flags over temp.
    Clearly theoretical but would explain it. Can only guess that the stretching of a bag as its extended to raise the sus to get the wheels off (droop) has opened a hole?
    Failing that the compressor has failed at the same time and is not pumping effectively with the same outcome.
    2007 Audi RS4 (B7)
    Markus1 Guest
    I think you have it Jeffster. I opened up the compressor cover. Looks fine in there, no damage. Started the car, compressor ran for about 2 min then shut off as per normal without any overheating error code.
    Took it for a short spin, rear is properly up but front only came up a little. After 5 min the overheating message is back. Now it's parked with battery disconnected. Hopefully by morning I can see which front bag is pooped.
    Will post update.
    Mark
    Sep 2014
    Baldivis WA
    Sounds definitely like an air leak. The compressor should not run for 2 minutes to raise the car. About 20-30 seconds from access height to normal height is the norm for mine, same for normal to off road height.
    also check that the air receiver (tank) has not been damaged. This is located under the drivers side right next to the chassis rail and is a long cylindrical tank.
    cheers,
    Eric
