Results 1 to 10 of 15
Thread: Which way’s best...
    Aug 2010
    Sunbury, VIC
    Which way’s best...
    So, something that has been gnawing at me for a while. The hitch on the Hilux makes it impossible for me to have the van exactly level behind it - up until now, I’ve had it set up so it sits about 35mm lower than straight. Putting the DO35 pin back on the hitch tonight (yes I really need to get another hitch) I thought I’d try it the other way around - it sits about 35mm too high now.
    So, which way is better here? Or am I being too pedantic about it? Suspension is load sharing so it doesn’t really give a rats I shouldn’t think given the small amount I’m talking about here. My only thought was that if I had it back around the other way so it was 35mm too low, then it may save a few cents on fuel not sticking up so far (but I don’t pay for that anyway) and the centre of gravity is marginally lower. Seems to tow exactly the same - just took it for a blat down the freeway - sits on 90 to 100 with ease. Pics below.
    Thought? Did someone say “Just suck it up Princess”? 😉
    Untitled by Gavin Gregory, on Flickr
    Crafers West South Australia
    Clearly you need more junk in the back of the ute to lower it 35mm...
    Aug 2010
    Sunbury, VIC
    Assume for the moment that I like to keep the entire rig legal... 😉
    I have a toolbox, caravan spare, large trolley jack and compressor in the back - probably 100Kg all up. It may have some bags, an Engel also going in it plus a front and back seat passenger (who probably weigh as much as me between them).
    May 2016
    Which way’s best...
    35mm is nothing. Use which ever way works best for you. It’ll make no difference to fuel economy. 35mm at the towball equals maybe 2mm at the caravan. There’s no ‘legal’ associated with level Which way’s best...
    Apr 2011
    Wandong,Victoria,Australia
    Given the fact that the van is taller than the Hilux, regardless of the +/- 35mm... Does it really matter in relation to fuel consumption?
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    May 2003
    On The Road
    Yes you are being pedantic.... run it tail down...
    Feb 2005
    I’d get a hitch that made it sit level....
    It not than I would have it nose down.....
    I have also noticed that some hitch have a different rating depending which way you use it.
    Aug 2016
    I dont know the "science" or physics behind it, but most people who tow caravans and also "experts" say that for stability the van should be level or with a slight lean to the front. I would load up the van accordingly or change the pin height on tow bar to get that angle.
    2016.5 TDV6 Graphite D4,Corris Grey,APT sliders,Goe air comp plate,UHF & HF radio,Airflow snorkel,Discrete Winch,Compo rims with 265/65/18 Wildpeak AT3W, LLAMs,Traxide dual battery,EAS emergency kit,Mitch Hitch EGR blank & delete,ECU remap
    Aug 2010
    Sunbury, VIC
    Thanks - yeah, a new hitch is on the shopping list, but it would need to be custom made as all the off the shelf ones are not the right height - guess I could buy one of those overly large and complicated adjustable ones too...
    I'll swap it around and run it slightly down for this weekends run - it's only a few hundred KM.
    Thanks for everyone's thoughts.
    Aug 2010
    Sunbury, VIC
    This would work in the top most position - HAYMAN REESE ADJUSTABLE TOW BAR BALL MOUNT TONGUE HITCH TRAILER 4WD 70202 70207 | eBay
    Not sure if I like the price though....
    Will drop in and see the Engineering Supplies I use to see if they can make and certify one for me... Probably cost the same doing that anyway...
