Thread: LLAMS throttle closer for TDV6/SDV6/TDV8/SDV8 - runaway protection
    NSW SW Slopes
    For those who are concerned at the possibility of engine runaway from a blown turbo seal, this is a small module that gets wired into the throttle butterfly motor circuit (2 for the 3.6 TDV8) to close the butterfly for 15 seconds every time the ignition is switched off. Fitting the kit may void warranty due to the need to cut and splice into the 2 throttle motor wires. The initial modules are fitted with soldered links to configure the module for the throttle motors on a TD/SD V6 or TD/SD V8 engine. If the batch of original pcbs looks like being used then another batch will be produced which will be fitted with configuration DIP switches.
    The kit requires hard-wiring - it is not a plug-in kit. The kit is being provided, at least initially, for $30 including GST plus $10 postage in Australia paid by EFT, with postage to other countries provided upon request. Note that 3.6 TDV8 engines require 2 kits but only 1 postage cost.
    This kit has NOT been tested on a high-revving engine as a good turbo might get damaged. However my 4.4 TDV8 stopped quite abruptly when switched off from 2000 rpm on light throttle, not that I'm accustomed to doing this.
    Here are the initial fitting instructions.
    Throttle closer installation.pdf
    Brisbane, Queensland
    Thanks Graeme. That’s cheap insurance. I’ll take a 3.6 kit.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    NSW SW Slopes
    Just resurrecting this thread...
    Since initially posting this thread I found a 3.6 pcm DTC that is logged when the pcm detects unexpected revving and has forced the engine to stop by closing the EGR butterflies and therfore the suggested 2 kits might not be required. It would seem prudent to check if the 3.6 butterflies are or are not closed for several seconds when the ignition is switched off.
    RAR110: I don't recall sending you kits, but IIRC you no longer have the L322 anyway.
    Jan 2010
    Unfortunately this won't work on D3's with the EGR Delete as the butterfly fly would have been removed...Land Rover Discovery 3 Range Rover Sport Jaguar S-Type TDV6 EGR Removal Blanking Kit Blank Plate Instruction Guide : 8 Steps - Instructables.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by RANDLOVER View Post
    I have this "problem". The butterfly went in the bin with the EGR pipes and DPF a few years ago. On the other hand, with a gearbox and third pedal I can stop it any time I want.
