Results 1 to 10 of 32
Thread: replacement headlight bulbs.
    May 2003
    On The Road
    looking at upgrading my headlight wattage.
    found this;
    <span style="color:red">PIAA GT-X replacement bulbs are designed with an exclusive purple low beam and an Xtreme White high beam. A purple topcoat gives the headlamp a bluish-purple look even when the lamp is turned off. GT-X bulbs feature PIAA's Xtra high efficiency technology that produces greater light output than the bulb's rated power consumption (for example, a bulb that consumes 45/65W of electricity has a light output that is similar to most 95/120W bulbs). GT-X bulbs are street-legal in Canada and all 50 U.S. states.
    PIAA Xtra Technology Wattages
    Example 55watts = 85watts of light output
    H3: 55w = 110w
    H4: 60/55w = 135/125w</span>
    I know there have been posts on this subject before,, but not a lot.
    maybe mines the only d2 around without a front bar :roll:
    anyway, whats the go these days with higher lowbeam than hibeam wattages??
    and whats legal around town?
    Yass NSW
    Don't know the legalities but mine has 90/130 what lights and passed rego.
    Jul 2003
    There are plenty of replacement globes about that don't emit that ghastly blue light.
    I have Osram +50 and as they run at the same wattage as spec they should be legal. They helped but....
    However the best thing I ever did was to employ drivesafe's wiring upgrade. (In the Projects and Tutorials Section). Welshman is doing this to his D2: http://www.aulro.com/modules.php?name=Foru...iewtopic&t=5356
    My Disco's lights are now as good if not better than any lights on the road.
    And legal just working at their designed output.
    Mahn England
    Ex 300Tdi Disco:
    Yass NSW
    The previous owner had already done the relay upgrade like drivesafe's project. Well worth it.
    JackH Guest
    The legal requirements are 55/65w but unless someone actually does a physical inspection who would know.
    The only thing that bothers me is the insurance aspect. Insurance companies are so pedantic at times that if you had an accident and they found your lights weren't 55/65w they might spit the dummy and wipe your policy 'cos the vehicle is not street legal.
    I've got the Narva +50 and they are great and street legal at 55/65w but I'm going to look at drivesafe's wiring upgrade
    Jack
    tombraider Guest
    I'm running IPF "Fat boys" in my 'fender and their great.
    Bit pricey though.
    Mike
    Toowoomba QLD.
    Bit pricey though.
    Mike
    Ditto.
    Trev.
    May 2003
    On The Road
    Originally posted by p38arover
    Read this first: http://www.danielsternlighting.com/t...lbs/bulbs.html
    yep, ok,, so Mr stern poo poos coloured lamps, and "85w from 65w bulbs",
    good info, but it doesnt get me a "100w high beam on oem wiring"
    Jul 2003
    Originally posted by Pedro_The_Swift+--><div class='quotetop'>QUOTE(Pedro_The_Swift)</div><div class='quotemain'><!--QuoteBegin-p38arover
    :?[/b][/quote]
    Mr Lucas B'st'd probably measured it in candelas or the number of unprotected candles still illuminating in a stiff breeze.
    Mr Stern Esq. measures light output in Lumens and not Whats.
    Pedro, I will swap over my Osrams for the OEM this weekend and with the trusty light meter I can measure the difference in Lux
    :wink:
    Mahn England
    Ex 300Tdi Disco:
