Results 1 to 10 of 19
Thread: Help required in Melbourne!
    Aug 2018
    Hi all, I think I’ve introduced myself briefly before but I’m a relatively young pup with limited mechanical experience, with a pretty well-refreshed 88” 2A.
    I’ve spend the last week fighting with my braking system - rebuilt the CB-type master and now I cannot get it bled. Have been doing it manually because I don’t have a vacuum pump, and I’ve run out of will and time to do it, and I can’t drive it to a garage! Does anyone know a good old-skool mechanic who would come out, or does anyone want some cash to come and get it back to roadworthy?
    I’m in Melbourne’s inner west, Yarraville area.
    Moderators, please direct me if this is posted in the wrong place, I’m a little overwhelmed by the size of the forum 😳
    Thanks all
    Free Again Thanks Dan
    Have you got a old M/C cap or can you get one to suit ?
    I have in the past drilled a hole in the cap and fitted a tubeless valve and pressure bled with a push bike pump
    I still have a cap with valve but not sure it will suit your M/C .
    The cap i have will suit a Defender type clutch M/C , I have a SWB S111 so will see how it fits
    Im in Narre Warren and could possibly come over after xmas day and help but my time would be brief as i only have the main week off .
    I know a guy. Hes busy till after xmas.
    He might have an appy on hand for the first weekish of jan
    Aug 2018
    Thanks for the speedy reply. I have the original reservoir with the clutch master reservoir down the centre, and the brake fluid around the outside. No spare cap.
    I’ll be around on Boxing Day but probably back to work on the 27th. Otherwise evenings.
    Let me know if you have the time free!
    Aug 2010
    Sunbury, VIC
    Bad time of year for me unfortunately - would be happy to help but heading off tomorrow and won’t be back in Melbourne until the new year now. If you aren’t in a rush I can assist then.
    Oh - welcome to the forum. 👍😉
    Aug 2018
    Thanks @Homestar, get in touch when you’re back anyway and we’ll go for that coffee
    Aug 2010
    Sunbury, VIC
    Sounds good mate - I’ll PM you my mobile number - zap me yours back if you want. It sure what day I get back, but will keep you in the loop. 👍
    May 2009
    When I lived in Yarraville and couldn’t bleed the brakes on my 2a I took it to Dennis at Footscray brake service in Geelong rd. I drove in low range and nipped up the hand bake and used all the side streets.
    Geelong, VIC
    Does a vacuum bleeder work ok for the S2?
    If so I can give you a hand on the evening of 27th after work.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by steveG View Post
    Steve
    Yes, vac bleeding or pressure bleeding from the MC seems to be the most effective way, but I’ve also had luck with gravity bleeding over many hours too.
