Results 1 to 3 of 3
Thread: Land Rover Coolant
    Yea, Victoria, Australia
    Land Rover Coolant
    Hi there,
    My sister has a Discovery Sport 2017 model. It has a low coolant sensor on.
    JLR say to use STJLR.651.5003
    Can someone tell me what the cross reference coolant is that can be used.
    Richard
    Cutch Guest
    I'd check it isn't a sensor fault. Coolant shouldn't be escaping and if it as the cause needs to be established.
    Brisbane,some of the time.
    Quote Originally Posted by Cutch View Post
    And it should be under warranty,dealer needs to sort it.
    If it does need topping up to get to the dealer,or in emergency,I would add demineralised water only.
