Results 1 to 10 of 13
Thread: Poor fuel consumption
    Jul 2011
    Logan
    Hi all
    4bd1 N/A lt95 box.
    Poor fuel consumption compaired to others I have heard of.
    average of 14.5lts per 100.
    I do all high way kms at 100 kph. Have replaced all filters and replaced screen.
    I run inner and outer air filters. Doesn't appear to blow much black smoke .
    I can't work out why it would be so high compaired to others on here and those I know.
    Any ideas?
    Matt
    Apr 2011
    Wandong,Victoria,Australia
    Hi Matt,
    Silly question time (from me that is).
    Have you:
    checked that your tyre pressures are set to highway speeds?
    checked that your rear (drum) brakes are adjusted?
    checked that your hand brake is adjusted correctly?
    Checked the wheel bearings?
    Replaced/checked your diff oils?
    General service - oil, filters, etc?
    Do you have anything like a roof rack?
    Larger tyres?
    I have a stock FFR - and running at 100kmh, I get around 10-11.5
    14.5 is higher than I would expect but I also get 25-28 in my 101 so 14.5 ain’t bad! Poor fuel consumption
    GG
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    Jul 2011
    Logan
    Hi GG
    Front and rear diff out of 97 defender so disc all round
    not sure about hand brake. Will need to check.
    Car has been back on the road for a year. All oils done back then. Engine done every 5000 since.
    Wheel bearing were good but will recheck.
    Tyres at 45 psi front 50 rear .
    32 11.5.15 tyres. So a little big but same rolling as standard. Give or take .
    Matt
    Jul 2011
    Logan
    Sorry do have a box and roof top tent on it
    Feb 2005
    Is the speedo correct??
    Jul 2011
    Logan
    No it appears to be 10 out so I been doing 100 on gps unit speed.
    Not sure if that's correct thing to do or not.
    Speedo says 110 kph when gps says 100
    Mar 2007
    Canada
    Also check the odometer reading. They are usually not out as much as the speedo.
    Beyond that aerodynamics is the big thing. Lift. Rack. RTT.
    Mine does between 10 and 11 and weighs over 3 tonnes. Drive at 110 all the time.
    Jul 2011
    Logan
    I do work it out by the odometer (maybe incorrectly).
    I don't try to take 10 percent off kms.
    Maybe I should try to work out the kms more accurately.
    Even still taking off 10 percent I am not down as low as others.
    10's and 12's are dream numbers for me at the moment.
    Matt
    Hay Point
    Might be worth getting the injectors checked. I am wondering if it may have turbo injectors in it.
    Cheers......Brian
    1985 110 V8 County
    Free Again Thanks Dan
    Quote Originally Posted by landiematt View Post
    This here my friend will be your major contributor to poor economy figures
