Thread: A bit of wood rot????
    Mar 2012
    Adelaide SA
    I pass this caravan regularly.
    Jan 2010
    Quote Originally Posted by DiscoKym View Post
    I wonder what state that caravan is in now?
    Also I was wondering what sort of success people have had using wood hardener to repair house timber (untreated pine), not load bearing of course? I have discovered rain getting into a soffit/eave has damaged some timber and plan to treat it with wood hardener, then putty, then screw in a new cement sheet as the old one just crumbled when I removed it, due to water damage I suspect.
    2005 D3 TDV6 Present
    1999 D2 TD5 Gone
    Jul 2019
    I have used hardener and then a 2 part builders bog, followed by surface coating with exterior varnish, to patch up dry rot in Oregon timber in a pergola. It has last about 8 years, but it is not load bearing. The patch could fall out if there was downward force.
    As your requirement is load bearing (cement sheet) I recommend supporting the rafter with a prop, cutting the rot out, and replacing the rotten part with a new section of rafter. Use a steel sleeve and fasten with nuts and bolts. It will then last as long as the rest of the eave.
    best wishes,
    Jeffoir.
    98 Disco 1 V8 (Gone) Young family; so much fun..
    00 Disco 2 V8 (Gone) Mrs Jeffoir's..
    02 Disco 2 V8 (Gone) What a lovely exhaust note..
    07 Disco 3 TDV6 Still going strong..
    12 Disco 4 SDV6 Mrs Jeffoir's..
    13 Disco 4 SDV6 Great days lie ahead Comrades..
    Jan 2010
    I have used builders bog turbo indoors when I changed my garage door around, to fill the hinge and lock recesses and screw holes, it was easy to use and is still good after a few years. I wasn't sure how it would stick to wood hardener, which is why I'm going to have to putty, but it doesn't have to be really strong as I still have strength in the side timbers as only the end one under a fascia board really half rotted away. My yachting mate said to fibreglass it all, but he loves that stuff, built his own fridge/freezer and dinghy out of it. I might still paint it all in bituminous/creosote paint to protect it if water gets in again, although I think I've discovered the three leak points.
    1999 D2 TD5 Gone
    Jan 2010
    Quote Originally Posted by Jeffoir View Post
    I have used hardener and then a 2 part builders bog, followed by surface coating with exterior varnish, to patch up dry rot in Oregon timber in a pergola. It has last about 8 years, but it is not load bearing. The patch could fall out if there was downward force..............
    If the patch does ever fall out, it seems the trick it to put a screw in the gap to be filled for the bog to bind to, obviously making sure the screw head is below the level of the finished surface.
    1999 D2 TD5 Gone
