Results 1 to 10 of 16
Thread: Power steering leak
    Sith Guest
    Power steering leak
    Howdy guys , have just developed a leak from the steering box itself ....just don't know where :? :?
    Went up to the local shop after work to pick up my daughter and between home and there maybe 3km's lost half the resivoir 8O 8O
    It's running along the chassis , down the tiedown loop onto the bash bar ......no leaks from hoses , no leaks ontop of the box at all .......the pinion section is dry and clean ......
    It leaks that is obvious ......but where 8O and what is there to be done ? any idea's ?
    thanx in advance
    Jul 2003
    Have you checked the pump and its associated hoses?
    Leaks can travel along way.
    Is the fluid aerated in the reservoir?
    Mahn England
    Ex 300Tdi Disco:
    Sith Guest
    no the oil isn't airated and all the hoses are dry , and all clamps tight ....just had it running and got my wife to turn the wheels left to right and it ran out .....when the wheels are straight nothing .......turn the car off and just drips ......buggar right on Easter :roll:
    Wheelers Hill, Melbourne
    With that kind of loss it's probably the input shaft seal, it won't run down on to the drop arm either.
    Box Hill, Victoria
    So what causes this?
    I have intermtant PS problems as my fluid heats and becomes aerated :?
    Happened today badly.
    Sith Guest
    from all the mech books i have read tonight airation is caused by the pump or lack of , hopefully it won't be a $million to fix :roll:
    buggar :? :?
    SYDNEY -in the shire.....
    <span style="color:blue">hey sith....what car...?
    and what year.....?
    send me an email and i will send a picture of a box.....this should help you
    to find the leak......
    until then....wash it down with degreaser and make it leak again so you
    can find exactly where the leak is.....</span>
    Sith Guest
    thnax mate will do today , don't have a dig camera so will have to wait for my sister to come over !
    Jul 2003
    Originally posted by DaveS3+--><div class='quotetop'>QUOTE(DaveS3)</div><div class='quotemain'><!--QuoteBegin-one_iota
    Happened today badly.[/b][/quote]
    In my case the PS pump is in two parts sealed with a thin (what looks like) neoprene gasket bonded to one of the halves.
    The gasket ruptured in one small place blowing out copious amounts of PS fluid and presumably also sucking in air as it cycled causing the fluid to aerate.
    Intermittant operation of the PS was the symptom.
    The gasket isn't replaceable so a new pump was required.
    Mahn England
    Ex 300Tdi Disco:
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    hmmmm, i have the very first symtoms of this i think... every now and then in the carpark the steering switches into hercules mode.... bugger... might have to buy some spinach...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
