Results 1 to 8 of 8
Thread: Front prop shaft replacement options.
    Aug 2011
    Hunter Valley NSW
    Gents,
    Due to lack of care on my part, the front prop shaft gearbox side uni has failed and damaged the shaft side ears.
    Given it is a fast wear component and I have just added a bit more torque with an engine swap I was contemplating swapping the whole shebang for an up-rated unit.
    Given it only has a 0.5" lift (which will most likely settle as the springs are new) I am think the Wide Angle HD is the best combination of cost, longevity and DIY serviceability....I know from experience the double cardans are a PITA to work on.
    300tdi / TD5 Front Double Cardan ULTRA EXTREME Wide Angle HD Prop GL-DC-ULTRA-EXT-600 – GwynLewis4x4.co.uk
    300tdi / TD5 Front Wide Angle HD Prop Shaft GL-EXT-600 – GwynLewis4x4.co.uk
    Besides the Glynn Lewis wide angle HD & Extreme wide angle offerings who else should be on the short list?
    NSW far north coast
    I was starting to bind my original prop at the t/case end so went with a Tom Wood DC shaft.
    It uses greasable 1310 Spicer unis at the three points and cost less than getting one made here including freight from the US.
    Wandiligong Victoria
    Vote 1 Glynn Lewis,
    I did the same as you and got my money’s worth out of the old one.
    May 2006
    Woolgoolga
    I have a tom woods with 1310 unis in mine, it's been great. Dc isn't needed imho, and just something else to go wrong.
    I have seen a few of the gwyn lewis is jobbies fail in the uni, but it was only rears.
    Oct 2012
    FNQ
    1310 -1350 Ford yoke just needs some trimming in a lathe
    JDNSW's Avatar
    "Given it is a fast wear component" ?
    My front prop shaft has only done 640,000km - should I start worrying? (replaced one cross and bearing from memory - before any further damage occurred)
    Jan 2019
    Townsville
    APT Off Road
    Quote Originally Posted by Fubar View Post
    Gents,<br>
    <br>
    Due to lack of care on my part, the front prop shaft gearbox side uni has failed and damaged the shaft side ears.<br>
    <br>
    Given it is a fast wear component and I have just added a bit more torque with an engine swap I was contemplating swapping the whole shebang for an up-rated unit.<br>
    <br>
    Given it only has a 0.5" lift (which will most likely settle as the springs are new) I am think the Wide Angle HD is the best combination of cost, longevity and DIY serviceability....I know from experience the double cardans are a PITA to work on.<br>
    <br>
    <a href="https://gwynlewis4x4.co.uk/product/300tdi-td5-front-double-cardan-ultra-extreme-wide-angle-hd-prop-gl-dc-ultra-ext-600-new/" target="_blank">300tdi / TD5 Front Double Cardan ULTRA EXTREME Wide Angle HD Prop GL-DC-ULTRA-EXT-600 – GwynLewis4x4.co.uk</a><br>
    <br>
    <br>
    <a href="https://gwynlewis4x4.co.uk/product/300tdi-td5-front-wide-angle-hd-prop-shaft-gl-ext-600/" target="_blank">300tdi / TD5 Front Wide Angle HD Prop Shaft GL-EXT-600 – GwynLewis4x4.co.uk</a><br>
    <br>
    Besides the Glynn Lewis wide angle HD &amp; Extreme wide angle offerings who else should be on the short list?
    <br>
    Speak to Be at APT Off road he does a HD prop based on a F truck shaft
    <br>
    Apr 2013
    Cairns
    I have front and rear Gwyn Lewis HD DC shafts. Around $1600 landed for both. About the same price I was quoted for just the front here. 1310 unis, very well made.
