Thread: 4bd1 and lt95 chassis mounts
    Jul 2011
    Canada
    Are there any photos or drawings of what the 4bd1 chassis mounts look like? Measurements would also be great.
    I'm looking to fit a 4bd1t into a 200tdi style defender chassis.
    Does the perentie lt95 use standard 110 rover lt95 chassis side mounts.
    Hay Point
    The gearbox to chassis mounts are the same.
    Cheers......Brian
    1985 110 V8 County
    Jun 2016
    United States
    Looks like one of my old posts has images and a page from the manual with part numbers. I don't have dimensions handy but could measure to confirm a dimension if needed. Scroll thriugh the following link here to see if this helps cross reference in any way. Passenger side bracket?
    I am in the States and may have a spare bracket or two from a 4bd1 I salvaged (haven't yet rebuilt it) to measure as well, but can't get to them from where I'm at now.
    Scratching my teenage itch now that I'm in my midlife crisis...
    '87 110 County 4BD1+T+LP (Godzilla)
    '88 110 Perentie Cargo 4BD1+T+LP (Thing1)
    '91 110 Perentie Cargo 4BD1+T+LP (Thing2)
    Aug 2011
    Hunter Valley NSW
    Murray at Rijidij Off Road – Custom Land Rover Solutions will sell you a set of weld in mounts at a very reasonable price. I used a set for my Td5 to 4BD1T conversion....they were spot on and gave the engineer warm and fuzzies.
    You should find the holes needed for the standard LT95 triangular plate mounts are already there on your chassis....forgive me if that what 200's come with as I never owned one. For my conversion once I cut off the R380/203 mounts a LT95 slotted straight in.
    May 2006
    Woolgoolga
    For engine chassis mounts, you can get them from Rijidij Off road if you don't want to make them
    Jul 2011
    Canada
    Thanks guys! Those are just the sort of photos I needed.
    I didn't see the mounts on the Rijidij Off road web page so I've submitted an inquiry to see what they have.
    Jul 2011
    Canada
    Yes they have the mounts and I've ordered a set, thanks for the help.
