Thread: LT95 Intermediate Shaft O-Rings
    Aug 2009
    ACT
    I've got a leak from the end cap of the intermediate shaft. According to my catalogue, the 2x o-rings for the TRB intermediate shaft are R532323 & RTC6167. Does anyone know the dimensions for these? Obviously I could remove and match them at a bearing place, but since this is my only vehicle, it would be just logistically easier to have them beforehand.
    I'm also hoping that I can remove the shaft bolt and cap while my mate holds the shaft / gears / bearings assembly in place from the access panel, replace the o-rings then just refit the cap and bolt - i.e. do the job without dropping the whole assembly out as per the workshop manual. Does this sound feasible?
    Simon
    doable.
    its a pita to hold any shims in place. I usually pack the shaft ends with high tack grease like turntable grease through a grease needle to help hold it all in place.
    you can also wire the shaft in place with loops of tie wire (or brickies string) around the intermediate shaft and the input gear and output gears.
    Aug 2009
    ACT
    Appreciate the advice Dave, thanks
    Hay Point
    G'day Simon, I will measure up the O rings and get back to you later. Do you know which one it is leaking from. I am thinking that if it's the outer one you won't have to pull the bolt out completely, just pull the plug out enough to expose the O ring but if it's the inner one on the bolt you will have to pull the bolt out completely as well as the plug. If someone else is holding the intermediate shaft in position while you do this I doubt that the thrust shim will fall off the end of the shaft as there is not enough room for it to come out. lube the bolt and O rings before refitting the bolt. Retighten the bolt to 125 ft/lb when you are finished.
    Cheers......Brian
    1985 110 V8 County
    Aug 2009
    ACT
    Thanks Brian, much appreciated. I _think_ it's the outer one but can't be sure. I guess I'll replace it first per your suggestion as that seems relatively easy and see if it fixes the problem.
    Hay Point
    Quote Originally Posted by eeyore View Post
    The big outer one is 41mm OD 36mm ID (3.5mm thick) and the smaller inner one is 24.6mm OD 19.8mm ID and 2.4mm thick.
    Cheers......Brian
    1985 110 V8 County
    Aug 2009
    ACT
    Fantastic, thanks very much Brian.
