Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: What TDV6/SDV6 engine oil are you using?
    Dec 2009
    Baldivis WA
    As the title says, with my Td5 it’s any easy choice of Penrite HPR Diesel 5, but what is the ‘best’ oil for the TDV6/SDV6 engines?
    Penrite list three oils for the TDV6/SDV6 and Castrol say you need to all their tech department, which I haven’t done yet
    More specifically for my MY14 TDV6 (No DPF).
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Mar 2016
    Follow the Ford specification to be sure you are using the right oil. If you have a DPF then their Enviro C4 5W-30 product is perfect. If no DPF then the fully synthetic 5W-30 suits.
    No DPF product.
    2007 Audi RS4 (B7)
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    My indie recommended a 40 weight and apparently they use a Motul product in all the TD/SD engines.
    I'm using the Enviro+ 5w40. Hangover from when it had the DPF and I've just stuck with it. It seems to sit somewhere between a thick 30 and thin 40.
    Oct 2012
    Crazy idea but why not use the oil spec specified in the owners manual?
    Jun 2007
    Margaret River
    Ive been using this for in TDV6 2.7 and Puma 2.2. Both without DPF.
    As well as FORD WSS-M2C-913C approval it has Jaguar/Land Rover STJLR.03.5003 approval
    Total Quartz 9000 Future NFC 5W 30
    QUARTZ 9000 FUTURE NFC 5W-30
    Mar 2016
    Quote Originally Posted by BradC View Post
    I don’t risk using anything other than the spec as defined by LR given the propensity for crank failures in these engines. This may mean I’m actually adding more risk, but I’ll stick with the 30 weight and change it more often. I’m now down to 10k services versus the factory 24k which the previous owner followed.
    2007 Audi RS4 (B7)
    Jul 2016
    Blackstone
    I use Valvoline Synpower FE Full Synthetic Engine Oil 5W-30.
    It's what my indie used before I started doing the services myself.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Supporter
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by DiscoJeffster View Post
    I do 10k or 12 months unless I've been towing hard, in which case it's 6 months. I haven't hit the 12 month limit yet and if it's getting within the projected trip distance I'll do it before I go. I don't think I'll ever be comfortable with extending oil change intervals > 10k in a Diesel.
    I had a look at the specs when I did my original search and the HTHS is so close between the specified Xw30 Castrol and the 5w40 Penrite that there is nothing in it.
    My problem was when I originally looked for a viable oil I still had the DPF, and the Penrite was actually the best available fit in a full synthetic. Now I'm DPF free I could potentially change it up, but the Penrite also suits my other vehicles so I'll stick with it.
    Dec 2009
    Baldivis WA
    Quote Originally Posted by PerthDisco View Post
    Not crazy at all. I know my engine (MY14 TDV6) needs to be 5W/30 and meet specifications WSS-M2C913-B or C. But as the saying goes ‘Oils ain’t oils’.
    Maybe I should have asked “What 5W/30 engine oil, that meets specifications WSS-M2C913-B or C, are you using in your MY13 onwards TDV6/SDV6 engined Discovery”
    Mar 2016
    Let’s be honest, no one here can confidently and empirically say any oil is better than another other than those testing their oil, and even that isn’t a true comparison as there’s no baseline data. They can say though that their choice of oil is at least not bad. At the end of the day, if you stick to brands that meet the requested specification you’re pretty likely to end up with an oil with the correct additive pack included as the engineers designed it for. If you then change it more regularly then you’re likely to be a happy camper. Anyone who tells me Mobil this, Castrol that are generally falling for marketing.
    TBH I’d use any oil that meets the Ford specification that is best value at the time I need it. Maybe I’m a simple man these days?
    2007 Audi RS4 (B7)
