Results 1 to 6 of 6
Thread: Re-acquainted with my Classic LSE.
    Dec 2008
    Victoria
    I picked up my Rangie LSE from the Landy mechanics last week. It went in on a flat top due to an EAS air leak and was sitting on its bump stops. Well.......it wasn't an easy leak to find and it spent a tad over 14 weeks in the work shop. It was established early in the piece that the problem wasn't a leaky air line, air line connection or air bag etc. A smoke machine, soapy water etc were all utilised to no effect.
    Various parts were swapped over in an attempt to isolate the problem. One issue which had concerned me for some time was that the compressor would run, turn itself off and then recommence running within one minute or so. The suspension also huffed and puffed when ever a door was opened and then closed.
    Eventually this almost continual running caused the now very noisy compressor to burn out so it had to be rebuilt. Even then the EAS still leaked air.
    Long story short is that it turns out that the problem was a valve block intake valve leaking past its seal and going out the vent ports so the system couldn't make pressure and hold it.
    Now it is wonderful. I know everything is working properly because the car goes up and down when instructed etc and I haven't heard a huff or a puff at all. The compressor runs silently except for one time in a silent environment when I could detect a faint hum coming from it. The EAS now also holds its position when parked overnight as it should.
    Driving is a silent affair except for the sound of that V8. I am an exceptionally happy owner enjoying this unusual silent operation but I do so enjoy having the drivers window down to hear the V8 doing its thing.
    The result is well worth the $1500 this particular issue cost me. I also came home with a box of good tested second hand EAS parts which were handed over as a gift. Every day now I can't wait to go and drive it some more. Vrooommm........
    Feb 2013
    Ballarat,Vic,Aus
    Excellent ... the $$$ soon become a distant memory if your enjoying yourself
    Proper cars--
    '92 Range Rover 3.8V8 ... 5spd manual
    '85 Series II CX2500 GTi Turbo I :burnrubber:
    '63 ID19 x 2 :wheelchair:
    '72 DS21 ie 5spd pallas
    Modern Junk:
    '07 Poogoe 407 HDi 6spd manual :zzz:
    '11 Poogoe RCZ HDI 6spd manual
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Grumbles View Post
    I'm green with envy, even though I also have a 2nd EAS set from a 93 wreck.
    Mine went to Rovertech last April to address a couple of electrical gremlins, and I've not been able to drive it since, and still waiting - ever hopeful it is getting to the end of this particular episode. Now almost 9 months, but who is counting!!!!!!
    Short version is another person was playing with the Hybrid TD5 and LSE air/electrics and had the temerity to have a stroke and leave this mortal coil. Current sparky has had "fun" trying to reconnect a virtually dismembered electrical system in between other jobs. In hindsight I should have put a new loom in from day 1. I'm not even going to contemplate what the bill might be.
    Dec 2014
    FNQ
    Yet it is blindingly obvious why many would seek to remove the eas and replace with coil springs.
    cheaper.
    quicker
    easier.
    I can tell you I wouldn't leave a vehicle out of my possession for 9 months or even 14 weeks with someone else I was not on VERY good terms with and then to add insult to injury hand over 1500 bucks for the pleasure. I hope there is more of a back-story to this which you haven't disclosed. The way it reads to me, is that you had an issue and left it with a mechanic, and they took 3 months to find the leak... I hope this is not how it actually happened...
    Despite this "difficult to find leak" any suitable and properly thorough investigation should really have netted a correct diagnosis sooner - that is of course my opinion and others are welcome to disagree. I'm fine with that. But we are talking about an issue that can be replicated, because the leak is almost constant....
    I feel there must be more to this story than just a 3 month hiatus.
    Having to wait for some unobtanium part and it's related exhorbitant price? yes I can absolutely identify with that. It does cause unwanted, sometimes prolonged delays and it is out of your hands. There is always a degree of frustration in that.
    Having to wait for hoist time for your 'project' while your mate who owns the workshop has paying jobs? yes, absolutely can understand that. I have been in this situation as well. I digress:
    I did have a vehicle in my mates workshop for 3 years, when an automatic 5-speed 722.5 transmission he sourced failed for the second time less than a month after it was replaced.
    It was left there because the decision was made after the second failure (through no fault of mine) to convert the vehicle to a factory 6 speed manual transmission from a later model vehicle, something that at the time had not been undertaken by anyone in the world - we had reached out to experts globally and got nothing. Not even the Classic Centre in Germany had an answer or could even tell us if it was possible with factory parts.
    We had some answers - i.e. pieces of the puzzle, but some key ones were missing - the ones that "unlock" the picture and get you moving.
    During that time, I wasn't pressured or charged for storage, the vehicle ran out of rego and it suffered 'storage syndrome' where the rubber components slowly degrade from lack of use.
    The result was 3 years and 3 days after it was parked, the installation of the manual box was undertaken and completed in 4 days. This included custom fabrication of HD propeller shafts, shifter linkages, clutch lines, lockout electrics, a standalone VSS, rear crossmember etc. 90% of the conversion is factory off-the-shelf parts, albeit from about 4 different model vehicles. All of the research was pioneering, since then only a handful of conversions have been successfully completed in this way globally, but it is nice to see that it can be replicated - for a cost...
    The bit that took ages was the custom length 4140 propshafts with new weldyoke and upgraded uni which needed machining on the slipyoke and weldyoke to fit with the factory centre bearing and hanger. Scary stuff to get perfect - and it was done to perfection - but it was painstaking work and required a full mock-up to ensure angles were correct etc.
    So it's easy to understand why some people just cannot handle the delay, why your vehicle is stuck in a strangers workshop for more than 2 weeks or why people cannot understand why an owner chooses to wait for a specific solution, when other quicker, easier or cheaper solutions seemingly abound by comparison...
    The desired outcome is what drives decisions such as this, not the cost or the delays incurred.
    Having said all that, I wouldn't be waxing lyrical about the results of prolonged undertakings. Happy? yes, certainly. Just not overly-exuberant about it, because people don't understand the logic in 'waiting for the desired outcome' these days. (hint: gen-Y / millennial jibe)
    I am sure there is satisfaction in knowing it's fixed, PROPERLY - and driving around is enough to elicit a wry smile and a feeling of relief and a sense of accomplishment. That's how I feel when I get into the 300 coupe and row through 6 gears.
    Feb 2013
    Ballarat,Vic,Aus
    Quote Originally Posted by Mercguy View Post
    cheaper.
    quicker
    easier.
    It depends.... I have had peoples cars here for an extended period of time while they wanted me to ( try ) to fix them. In a lot of towns you probably won't find anyone that wants to work on an old range rover. In my case. Can you find anyone in Ballarat that wants to work on a 30+ year old Citroen ..... Not likely, so sometimes they end up at my place...
    Proper cars--
    Modern Junk:
    Dec 2008
    Victoria
    The story is as I recounted. Nothing hidden. Having an older and relatively obscure car can cause many problems when it comes to repairs in a rural area with not the least being finding some one who will work on them in the first instance. Then the question of do they have the relevant electronic equipment/special tools to work on the car - eg the EAS interrogation computer.
    Just for comparison - using a different workshop a mates Classic RR spent 9 months with its front end disassembled looking for a vibration. Then it had another stay of a couple months for an engine rebuild.
    But wait times are not solely confined to cars such as these. Mechanics are in short supply in rural areas and this leads to long waiting times for any car with the possible exception of those still under new car warranty. Even then replacement parts can be a long time coming.
    Re the expense of the EAS repair compared to replacing it with coil springs. I wanted the EAS and can afford the maintenance costs so not a drama. I can also see long term value in keeping an LSE totally original. But whilst it was away I got sick of driving my Suzi GV every day so I negotiated a good trade-in deal and purchased a Pajero. Lovely car and great to drive but it is now parked as I favour driving the LSE.
    Thanks for the comments guys and good luck with yours Gavin.
    Cheers all
