Not trying to be completely facetious, but what about running the tyres a few psi lower?
At the very least it'll give you an idea of what a softer ride'd feel like.
Simon
Hey guys
Thinking about a softer set of springs for my Defender. My vehicle is fully loaded in terms of accessories but despite this I think my springs might be rated just too damm hard - in addition I have polyairs on the back(running at 6psi truck empty) - just found on an old receipt that lists the springs ratings at:
Rear - 320lb
Front - 220lb
Just finding when running unloaded the car just jolts all over the road - am running Bilsteins and have not measured the lift on vehicle yet but it sits pretty bloody high.
What rated spings are you guys running and what sort of ride do they give you unloaded, I dont expect the truck to soak up bumps like a Lexus but at the moment on poorly paved roads it just bumps all over the place, affecting the stability/steering of the vehicle.
Daz
Simon
following on from Si's reply, what tyres are you running, and what pressures ?
Here's something to consider, I posed the same question a few months back to try and soften up my D2 ride. I have OME springs a shocks all round giving me about a 40mm lift 300-340lbs rear and 180lbs front. I have a winch bar (no winch) and run 275/75R16 BFG muds. I used to run the muds at 30psi all round on road unloaded to try and soften my ride up but it was still very jumpy on small bumps. On advice I now run all my tyres at 38-40 psi all round and this believe it or not has made the ride smoother. Not sure if it was the tyres trying to act as my suspension before and now the suspension is allowed to work properly but either way - unless something else has happened - my D2 runs much better at the higher tyre pressure.
Hope this helps
P.S. I am still about to change my springs rates to about 240lbs rear and will add polys and about 160-180 lbs front - am also hoping to achieve around a 2.5 true lift at the same time and soften my ride even more.
I've always ran my factory front Grabbers at 28psi as placard says tried them at 30psi the other day and the thing catches every set of bumps and shudders like **** thru the steering, scary.
Thanks for the advise so far guys - I have played with the tyre pressures a little, am running a tyre called a Mudstar 35x12.5x15 (mud terrain style tyre, soft compound) but have not gone under 30psi or over 40psi as mentioned - will play a little more and post results in a day or so.
Thks Daz
I don't know the spring rate in mine but they are heavy, I also have LTR shocks all round. I run my 285/75/16 BFG Mudds at 50psi on road and have gone as low as 20psi off road. I find the high pressure lets the vehicle role more happily and seems more stable and responsive.
I dont believe its the spring rate...
I'd say its the Billies....
Too stiff IMHO...
CHeers
Mike
Whilst I no longer run these springs as I changed to longer ones I had sitting in the shed which were softer rate (220Lb F / 320Lb R with custom lengths) I used to run the following:
Front 290Lb
Rear 360Lb
Shocks - LTRs all round @ 100psi
Firm onroad, but not jolting and drove like a dream! (2 trips Adl to Vic, including offroad in 4 weeks) empty on way over, laden on each return and yet still rode brilliantly.
Defenders flex fine with these springs (was initially apprehensive!) as can be seen here in Toolangi.
I'm betting your shock rates are too firm. This is a common comment from Bilstein owners.
Mike
i run the same coils with no problems.
My shocks are pedders crap... the Koni's were 2 stiff...
