LR refer to this issue as an "early service warning" issue, brought on by the car estimating oil dilution. There is no equipment in the car to measure actual oil dilution. You're not the first person to have their oil tested and so far I haven't heard of a single test coming back with actual oil dilution anywhere near the percentage that the car estimates.
LR have campaign N222v3 which is a software update, this should have been applied when you took it in for a service. Following this software update from my own experience (but I'd only done 200km since the update) that the "km to service" are more in line with kilometres driven.
Not sure if your test gave you the wear metals in the oil, which would be very high. So it is probably good to get the oil changed and LR should do this under warranty. Mine has had 2 oil changes, the first one was days before the N222 software fix came out, earlier this month it was applied and another oil change done.
Ron
				2016 D4 TDV6 Corris Grey
2018 D5 TD6 SE Silicon Silver - gone
2011 D4 TDV6 2.7 Indus Silver - gone
IIDTool BT
