Does the car lurch when cornering with the van? Perhaps the shocks are worn-out but check the ball loading and the van loading generally for heavy weights front and rear.
have a disco 3 2007 tdv6se with air suspension and i tow a 2.6 tonne 20ft caravan no problems on the highway but as soon as i hit a hilly winding road the dsc light starts flashing especially when coming downhill around tight corners the warning light flashs and then goes out every thing is normal but i have had the system break down completely twice once when towing up a rather long steep hill got three parts the way up and all the bells and whistles came on no suspension, transmission fault have had the auto box serviced since. the second time it happened i jumped on the brakes when traveling at around 50kph and the same thing came in only happens when towing have tried all sorts of speed and corners without the van no problems have no trouble rectifying the problem so far simply turn the vehicle off leave for a couple of minutes and the computer resets itself and away i go has anyone had this happen to them do i have to replace the air bag suspension being a newby to land rover i was impressed to stsrt with now beginning to wonder
 Swaggie
						Swaggie
 Swaggie
						Swaggie
						Do you see the DSC light coming on when going uphill?
Does the trailer dash light illuminate when you indicate?
Reason why I ask, is that of not then the car is not recognizing the trailer probably because of LED lights not providing enough resistance
This will prevent the car from going into tow mode which affects DSC, gearbox shift patterns etc.
You’ll need one of these (or equivalent) to remedy
LED Tow Connect - Tow LED Fitted Trailers Safely: Discovery 4
Hi,
I suspect the wording should be that the led lights have too much resistance and not providing enough current draw to trigger the 'trailer mode'.
However, when not braking, indicating or using lights, the caravan lighting circuit does not drawer power. So there must be something else to tell the vehicle a trailer/van is being towed.
Someone more knowledgeable than me may be able to explain what is happening.
 TopicToaster
						Subscriber
						TopicToaster
						SubscriberDo you have enough trailer braking engaged? It sounds like the trailer is pushing on the vehicle while it’s turning going downhill and possibly the yawing the vehicle as it senses the load of the trailer and is causing DSC engagement.
Maybe try enabling more trailer brake and see if that changes the car’s attitude and DSC activation. It should not do it.
2007 Audi RS4 (B7)
 Swaggie
						Swaggie
1. You are required by law to have a braked trailer if the trailer mass is in excess of 750kg. You can either have hydraulically braked trailer via the hitch, or the more popular electric brakes, in which case you need an electronic brake controller in the car, either the RedArc or Tekonsha P3 are good examples. These are relatively cheap and easily retrofitted by an autorlectrician or a handy DIYer.
2. The D4 (maybe D3 too) sends a signal down each indicator wire roughly every second or so (could be more often, I can't exactly remember) when towing. If the resistance is high enough (I.e. your trailer lights are or have been on), the car knows it has a trailer attached and adapts the DSC, ESC throttle and braking systems accordingly. it also cancels the reversing sensors and the auto levelling feature of the suspension. Even when driving without lights on, each time you signal, the trailer status is reconfirmed. So when you first hook up and plug in and do your light check, the car knows it has a trailer on.
3.however, the system appears to be designed for incandescent lights, in t that these draw more current than LED, so what a lot of people have experienced is that when towing a trailer with led lights, the car doesn't know it's towing and so the DSC, ESC etc are not modified. This can cause unpredictable handling and the car to fault.
The common solution is to fit load resistors either at the trailer lights, or into the wiring harness for the rear plug. This increases the line load so that the car detects it has a trailer on.
Also check your down load on the hitch at the car, if the van is not correctly loaded or too heavy, you'll have too much downward load, leading to instability when towing, worse downhill.
From memory (others here that have far more knowledge on this than me may be able to help further) I believe you are allowed a max downward load of 10% of the maximum towing capacity, so for D3/D4 this is 350kg.
Hope this helps
 Master
						Supporter
						Master
						SupporterI remember the first time I towed with my D3 and I didn’t have the setup that the car recognised I had a trailer on OMG it was a nightmare when I got to camp I fixed that issue let me just say the trip home was a lot more calm. The car changes a lot when towing if it knows there is a trailer behind you. Make sure when indicating you see the little trailer light up on the dash.
2010 D4 3litre twin turbo brand new motor 5km old on a 100,000km car. Kaymar rear bar, ARB front bar, Hannibal roof rack, Hella Predator Spot lights, long rand fuel tank, Traxide battery management. touring weapon.
