Tony have you got both grommets in place for the spare wheel winch?
The reason I ask is that when I was fitting my spare wheel winch adapter I used a mirror to have a look between the 2 floor skins. There appeared to be a surprising amount of daylight filtering into this space and I wondered if the lower skin allowed water to be drained out easily to give Land Rover the 900mm wading depth. That was the reason that I looked for a means of sealing the area around the winch so water does not come in and found the silicone tube that I bought from Autobarn, and cut roughly to shape.
The potential for dust ingress did not occur to me. I will be sure to put extra silicone sealer on top and bottom of the tube!
Julia
  Reply With Quote Originally Posted by Graeme
