Results 1 to 10 of 11
Thread: Drive it like I stole it
    Ean Austral Guest
    Gday All,
    Been getting the dreaded P0048 fault ,( Low fuel rail pressure or something to that effect ), only faults when the car is just coasting along usually at the speed limit. Everything I have read points to a HPFP issue , so decided to see if it would fault when it gets given some more eratic style driving , nothing outragous but a change from its normal life , bugger me it hasnt thrown the fault in 2 days. may be coincidence but doesnt seem so.
    It makes me wonder what it is in the fuel pump that faults when the car is basically just coasting along with no load ,but yet put the boot into the loud peddle and the thing just responds and performs like nothing is wrong.
    Cheers Ean
    NSW SW Slopes
    Could have been a sticky valve in the pump that's now had a cleaning.
    May 2003
    On The Road
    They say--
    Premium Diesel is just normal stuff with add-ons like injection cleaners,,,
    speaking of Italian Tune-ups...
    can you actually flog a diesel?
    bit like a dead horse?
    as i recall you have something much nicer to flog Ean,,,
    Oct 2012
    Ean its an interesting subject. Note the tacho has no redline marked and the engine will happily rev out 4000-5000rpm.
    Like you I doddle around <3000 but very occasionally hold down the gears going up a hill to rev it out under load.
    I assume there is no red line marked because the computer limits it?
    Sep 2012
    Adelaide Hills
    chaanged the fuel filter yet?
    Current Cars:
    2013 E3 Maloo, 350kw
    2008 RRS, TDV8
    1995 VS Clubsport
    Previous Cars:
    2008 ML63, V8
    2002 VY SS Ute, 300kw
    2002 Disco 2, LS1 conversion
    Sep 2014
    Baldivis WA
    I reckon with ~195kW and 650Nm of torque with twin turbo we can have some fun. I give it a bootful quite often and I love the look on people's faces when it takes off like a scalded cat.
    Ean Austral Guest
    Quote Originally Posted by Eevo View Post
    Gday Eevo,
    The old filter had 8100kms on it and yes I have fitted a new filter ,but am pretty confident it wouldn't be the filter. I would have thought a blocked filter would have worked the opposite way, causing issue when you put the boot in , not just cruising along
    Cheers Ean
    Ean Austral Guest
    Quote Originally Posted by PerthDisco View Post
    Its interesting that everything I have read on here and the Disco 3 UK site suggests that people just change the HPFP without any form of finding the main issue even if the fault is inside the pump itself. I guess you need to remove the pump anyway even if you were going to strip it down for repairs , so it would come down to the difference in cost between a new pump and the old pump repairs , as removal and install cost would remain constant.
    Cheers Ean
    St Helena,Melbourne
    4.28 MB
    I have been using sport mode for few weeks and usually boot it up to the speed limit, definitely makes it more fun and does surprise other road users and probably gives the cats a clean out.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2012
    Love to know logic of having no redline mark on the tacho? First car I’ve ever seen without.
    They rev like a petrol something you would never believe could be possible judging by diesels of even 20 years ago.
