Results 1 to 8 of 8
Thread: Camper Rim Hub & Stud Pattern
    Have a new camper on order. Given that I probably can't match my D4 rim hub & stud pattern what is the next best option in terms of rim versatility. For instance what 6 stud rims out there are interchangeable with each other. Does toyota fit nissan fit mitsubishi etc. in case I might need to borrow one sometime in the future?
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    May 2013
    Bittern Vic
    I am not sure about the D4 pattern, but you can get Land rover earlier stud pattern bits for axles. Unfortunately they usually cost a bit extra.
    Ian
    Bittern
    I thought P38A, D2, L322, L405, D3/4, D5 all use the same stud pattern - the same as Commodore 5-stud.
    May 2008
    Bundaberg Qld
    There is bound to be an exception but most of the common 6 stud rims are the same PCD.
    Sep 2009
    Commodore has the same pitch circle diameter as D2.
    5 x 120
    Quote Originally Posted by bsperka View Post
    D2, P38A, RRS, D3/4, and L322 are the same. I have a set of RRS wheels that I used on my P38A and they fit my L322. D2 and P38A are the same.
    So I reckon it's worth checking Commodore wheels/hubs.
    Avoca Beach
    The centre spigot size is different on a D2/38A from the D3 ( and D4?.)
    The D2 is smaller however this should not be a real worry on a trailer, except if you get wheels with a smaller spigot than the hub.
    I bought D3 adaptors for my trailer as the vendor didn't at that point have any D2 in stock and I had to grind down the adaptor as the D2 hole was smaller than the D3 spigot.
    You can get sleeves if the hub is smaller than the wheel, but IMHO for a trailer unnecessary.
    Regards Philip A
    Yes, I used hubcentric rings with the RRS rims on my P38A
