Results 1 to 10 of 24
Thread: Post-2007 D3 to Pre-2013 D4 2.7L TDV6 EGR reliability and blanking
    Feb 2011
    Hobart, Tasmania, Australia
    For the post-2007 D3's and pre-2013 D4's fitted with the 2.7L TDV6 motor I've read that blanking the EGR is not as simple as purchasing and fitting the blanking plate kit but rather requires additional ECU programming (e.g. this EGR deactivation patch file offered by BAS < Discovery(R) 3 2.7L EGR Deactivation Patch File (NOT ADVISED FOR ROAD USE) – BAS Remaps, Powering the Landrover tuning world! >). Once deactivated at the ECU are the same blanking plates as used on the earlier - pre-2007 D3 2.7L TDV6 then fitted - most of the for sale ads state it's only for pre-2007 models only but I cannot find any listing for later models so perhaps that's only due to the software patching required?
    What is the EGR system like on these vehicles? Reliable?
    Brisbane,some of the time.
    Quote Originally Posted by twr7cx View Post
    Cant answer the above,but your last question,you are much better off without them.They wear out and play up like everything.They also cause the inlet manifold to get full of gunk.And no,fitting only blanking plates will cause issues,you need the vehicle software changed as well.Many tunes include the software to delete the EGR's.
    And doing this and blanking them as well makes sure they are 100% closed.
    Mornington Peninsula, Victoria
    I got mine done after a failed EGR. It was going to cost a lot to get a new one so I took the plunge. Make sure you get a nice remap while your in there. MUCH nicer car to drive & good to know less crap is entering.
    Oct 2012
    And ideally delete the EGR coolers as well.
    Another source of trouble down the track.
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by PerthDisco View Post
    I was wondering about the coolers, they don't seem to get a mention when the topic of blanking comes up.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    I had mine remapped and removed the EGR's and blanked 'em off... much, much nicer to drive, feels like a different vehicle.
    P.S. hadn't even thought about the EGR coolers.... may have to do a bit of research on that topic.
    Who have you guys gone to to get the blank and remap? Would an MR auto be the goods?
    Sep 2018
    Watsonia
    I will be blanking my EGRs as I'm getting low level faults. I have the IID tool, so now who sells the best remap ie EGR/tune ??
    2010 D4 2.7
    Oct 2011
    Fremantle WA
    Quote Originally Posted by oldsalt View Post
    And for those interested, also the time to set up a sensor for EGT.
    Feb 2011
    Where's the EGR coolers and what's the process to remove them?
    Quote Originally Posted by theface26 View Post
    Quote Originally Posted by Sven94 View Post
    2010 D4 2.7
    Bell Auto Services (BAS) in the UK. Use your GAP Diagnostics IID Tool (if you don't have one yet then sort that out first).
    Remap - IIDTool Discovery(R) 2.7L TDV6 Remap – BAS Remaps, Powering the Landrover tuning world!
    EGR delete - Discovery(R) 3 2.7L EGR Deactivation Patch File (NOT ADVISED FOR ROAD USE) – BAS Remaps, Powering the Landrover tuning world!
    Blanking kit - TDV6 EGR Blanking Kit Pre 07 ONLY (NOT FOR ROAD USE) – BAS Remaps, Powering the Landrover tuning world!
