Results 1 to 10 of 14
Thread: Transmission seems tight when decelerating
    Tim81 Guest
    hi all, just signed up so this is all new to me, trying to work out How To navigate around this sight anyway I think I'm in th right place now. I have a 2008 2.7 turbo diesel discovery auto and I've noticed that when I take my foot of th accelerator it seems as though I am slightly applying th brakes and is worse as it gets into 1st gear like th transmission is tight or something, has this occurred for anyone else?
    Sep 2014
    Baldivis WA
    Sounds like engine braking to me, did you have it in sports mode?
    Tim81 Guest
    Quote Originally Posted by Eric SDV6SE View Post
    No, had it in d.
    Jan 2019
    Katherine NT
    Discovery 3 se
    You may have hill decent button on ! You will know this as it displays logo with vehicle on a slope.
    Tim81 Guest
    Quote Originally Posted by Laurie 123 View Post
    Nope, I tried pressing it while I was slowing down cause I thought th same thing but a msg flashed up on dash saying something like speed to high so it won't engage if your going to fast.
    Jul 2016
    Blackstone
    How long have you had the D3 and what vehicle did you have before it?
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Markus1 Guest
    It's not a racecar is about all I can say. What your experiencing could be just how it is. Try jumping in a mates disco if available.
    Then you can compare. But tbh unless youve got noise then I wouldn't worry.
    Tim81 Guest
    Quote Originally Posted by SeanC View Post
    Had a td5 and have owned the 3 since th start of this year but only just noticed this issue in th last week. Drove it today in sports mode and it's really noticeable in first, really resists when backing off.
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Tim81 View Post
    Are you sure that the vehicle is not in low range or a low range mode? A message like what you said above usually only appears if the cars in low range and you exceed the safe speed limit for the Transfer case. The air suspension also limits vehicle speed if in access or off-road height.
    when was the last time the transfer case, front and rear differential oils were changed?
    also, if driven normally the transmission rarely uses first gear. Normal start stop driving will use 2nd to move off,(saves fuel) Only in manual mode or in low range will it use 1st to get the most benefit of the torque converter lock-in up nice and early.
    Feb 2012
    Parkdale, Melbourne
    What does the tacho look like when this is happening? IE do the revs stay up and consistently lower in line with car speed? Or does the needle drop when you take your foot off, then the car slows while the needle remains low?
    Im wondering if it’s really transmission related or maybe handbrake dragging or something brakes related?
    - Justin
    '95 Disco 300TDI - sold
    '86 County 110 Isuzu
    2006 Range Rover Vogue td6
