Thread: coolant Weeping from the Expansion Tank
    Jul 2018
    Cranbourne
    Hi All just a bit concerned recently had the coolant flushed and refiled now there seems to be a weep on the screw plug on the expansion tank any ideas?
    Brisbane,some of the time.
    My Indie replaces the coolant tank whenever they do a flush on D3/4.
    Their reasoning is too many come back,tank fails,or the level float fails.
    And a genuine one is not expensive.
    I would just replace the complete coolant tank.
    Mar 2016
    I used a non genuine when I did my coolant. The sensor didn’t work and the bleed screw weeps as you suggest above. I reused my original sensor and apply extra tightening to the screw and it’s ok. Another fail for non-genuine stuff however.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Did my coolant flush after 8 years on same fluid and tank. I did not change the tank. I've got no leaks at either bleed screw. I did take them out completely and clean them up before putting them back in, they get some scale and residue on them. Perhaps remove them when the engine is cold and clean/replace the o rings on the bleed screws before replacing the entire coolant tank.
    Jul 2018
    Cranbourne
    Doesn't seem to be an O ring on the bleed screw i take it it should have one!
    Mar 2016
    Quote Originally Posted by gavinquinn View Post
    I think Eric might be mistaken. I’ve not seen an o-ring on the bleed screws and don’t believe it’s designed for one.
    2007 Audi RS4 (B7)
    Sep 2014
    Baldivis WA
    Oops, will check I thought it did from memory. Should know by now not to trust that too much
