Results 1 to 10 of 12
Thread: Discovery 3 front axle vibration on load i.e while accelerating
    Jul 2018
    Cranbourne
    Hi All
    another ongoing issue i have is a vibration which feels on the left hand side front - it is while it is accelerating first vibration is at 40 kph which is slight then it comes in again at 80 kph starting to last into the 90 kph when it its warm i.e over couple of hours on the road
    the other funny thing is its not noticeable on small journeys
    Cheers Gavin
    Mar 2016
    Typically tyre/wheel combo but your explanation isn’t completely aligned. If it’s not wheel balance or cold tyre flats spots (tyres flat spot when left overnight. They round out as they warm up). The other check would be of the wheel bearing on the left. Raise wheel off the ground and try and move the wheel onwards and outwards from the top/bottom.
    2007 Audi RS4 (B7)
    Jul 2018
    Cranbourne
    Quote Originally Posted by DiscoJeffster View Post
    Left bearing was checked same time the right one was shot we shall look at this though
    Jul 2018
    Cranbourne
    Ok been a few weeks and have been trying a few things, Brand new rotors were put on the front, wheel balance and rotation now progressed to my of a vibration at 40kph 80kph with I kinda grip grip not a gradual power through the drivetrain and steering wheel vibration on quick highway braking
    Jul 2016
    Blackstone
    Never thought of that. Makes sense. Learn something new ever day.
    MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
    Jul 2018
    Cranbourne
    Quote Originally Posted by SeanC View Post
    ;Does make some sense with the weight of the car but its not that
    Adelaide - Torrens Park
    Front differential bearing failure is common.
    Markus1 Guest
    Don't rule out the other wheel bearing. My front left was very slightly noisy for about 3000km but had zero play. After that it got more obvious after a bunch of water crossings and then I noticed just a tiny bit of play. But very very slight and I could have easily not spotted it. Then still did another 4000km on it before replacing just recently. Even finally in the end the play was still minimal. Probably gambled on it a bit too long in hindsight....wont do that again.
    My symptoms were a little like yours....sort of...I'd get a vibration/drone around 40kmph and then again 60kmph through to 70kmph. Didn't matter if accelerating or decelerating or coasting in neutral. The vibration was not through the steering and more generally through the floor.
    I don't know much about diffs, but I guess a bearing on the output shaft might mimick similar to a wheel bearing.
    Jul 2018
    Cranbourne
    Bit further on a few mechanics have jumped in and have said its not the Bearings as this is only there as its powering up in speed and not on deceleration it seems to be going through the body and seems quite central to the car.
    The tail shaft was replaced due to the chuckle wasn't running smoothly and centre bearing seal coming apart
    Mar 2016
    Has that resolved the issue?
    2007 Audi RS4 (B7)
