I don't know if I'm misunderstanding you, but the size of your tyres wont affect the angle of your axle shafts.
The Johnson rods will change the angle, and there are two ways to change it back - remove the johnson rods, or lower the diff and subframe. The latter option is not very common, and is likely expensive!
I have the GOE adjustable rods, which i can change back to standard height. Others use Llams.
If you are keen to run larger tyres, than AFAIK you will either have to live with the larger axle angle, or lower the subframe(s).
