If not overfuelled, High EGT could be air intake restriction or boost leak. Do you have a boost gauge?
 Fossicker
						Fossicker
						I’ve had a basic tune in my 300tdi, boost pin rotated and star wheel wound in. I then went away for the weekend and noticed the car floor seatbox was hot. I’ve decided to put an egt on and check what the exhaust temps were. Very shocked to find I could easily get to 730 (backed off at this point) unloaded and cruising up a slight hill near home. Now when I went away I was towing a smallish trailer and the car was more heavily loaded, so i can only assume I was reaching damaging levels. What else can cause such high EGT’s? Car isn’t blowing any black smoke at all and i can’t see any exhaust restrictions?
Where do I go from hear? And how should I check for damage?
 Fossicker
						Fossicker
						I do have a boost gauge, its a digital gauge and seems to be reaching around 19-20 max (takedn from the inlet manifold). It does however fluctuate up and down a bit as the boost is climbing but I always thought this may just be an issue with the gauge.
Regarding the air intake restriction, do just mean a dirty air filter or is there something else I should check?
That's a lot of boost if it's the standard turbo. Has it been fiddled with? The fuel pump mods won't effect it that much for boost. The compensator on the injection pump basically shovels in more coal when it sees more air. Restrictions, particularilly downstream of turbo compressor, are going to cause less air more temp.
Apart from the super boost I'd say you've just wound up the fuel too far.
^^^^^^ Just do it....
 Fossicker
						Fossicker
						then let us know
2007 Discovery 3 SE7 TDV6 2.7
2012 SZ Territory TX 2.7 TDCi
Road Trip?
from the phone call...
sounds like its been overtweaked for the available boost.
